Wiring For Recessed Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 10-04-2005, 01:58 PM   #1
wiring for recessed lighting
Afternoon, I need some assistance please. I am installing two sets of recessed lighting, each set will have its own dimmer switch. There is only one power line, a 14-2, that will power both sets. I currently have 14-2 running for each set. How do I connect the dimmer switches to supply power to both sets of lights? How do I wire the lights? Will I need a 14-3 wire? Thanks!
krw3153 is offline   Reply With Quote
Old 10-04-2005, 02:39 PM   #2
rspainhower's Avatar
you should have your power going in to the switch box and then from each individual switch run a daisy chain line through that set of lights.
But I am not an electrician so maybe the pros can tell me if I am right or not.
rspainhower is offline   Reply With Quote
recessed lighting wiring to 3way switch DIY4EVER Electrical 1 07-12-2007 02:35 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
recessed lighting WIRING tj home Electrical 29 10-31-2006 08:50 AM
Recessed lighting wiring? Kriv Electrical 2 10-17-2006 03:21 PM
Installing new lighting on knob and tube wiring drichard Electrical 1 03-05-2006 03:55 PM
