Wiring A Receptical With 3 Wires? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-10-2011, 05:34 PM   #1
wiring a receptical with 3 wires?
i have an electrical box, single gang for 1 outlet. It has 3 seperate wires coming into the box, one coming from another outlet, that will supply the power, and two wires leaving the box to go to two seperate outlets. all three wires have a ground.
My question is how do i wire this right.
Thanks for the help guys.
mac16m83 is offline   Reply With Quote
Old 04-10-2011, 06:31 PM   #2
joed's Avatar
Rewards Points: 12,458
Two ways to do it.
Find receptacles that can accept four wires under the screws. These are called back wired and have a flat plate under the screw. One wire can go under each side of the plate(two per screw) allowing four wires to be connected to each side.
Pigtail the three wires with a short pigtail of the same gauge and colour. The pigtail connects to the receptacle.
Old 04-11-2011, 05:36 AM   #3
if i pigtail the three wires together, with a short pigtail going to the receptical, that will be 4 wites together. is it okay to connect 4 wires with 1 wirenut, do i just use a larger wirenut?
Thanks for the help.
Old 04-11-2011, 07:47 AM   #4
joed's Avatar
Yes, there will be four white and four black. Use the proper size wire nut and four wires will not be a problem.
My utility room's wiring, before rewiring WillK Electrical 0 01-07-2011 10:44 PM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 07:07 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
Range Outlet Receptical Wiring - PICS nave Electrical 45 05-29-2008 06:37 PM
