Wiring Receptacles - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-02-2009, 05:32 AM   #16
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Not sure if it applies to "pigtailing" but here goes: Good for general purpose anyway.
300.14
at least 6" of free conductor measured from the point in the box where it emerges from it's raceway or cable sheath, shall be left at each outlet, junction, and switch point for splices or connection of luminaires or devices.
Where the opening to an outlet, junction, or switch point is less than 8" i any dimension, each conductor shall be long enough to extend at least 3" outside the opening.
wirenut1110 is offline   Reply With Quote
Old 03-02-2009, 11:21 AM   #17
DIYer
Originally Posted by Bocolo View Post
Thanks 220, makes sense. I take it pigtail lenghts are not discussed on NEC. I am still unable to find it. Thanks again.
The NEC is not a how-to manual.
Gigs is offline   Reply With Quote
Old 03-02-2009, 05:01 PM   #18
Rewards Points: 150
Send a message via AIM to Bocolo
Gigs, I was not asking how to wire a pigtail, I was asking how long it should be. I figured if the NEC gives you requirements (minimum) on just about everything else regarding distances, lengths and so on that there might be a required lenght for a pigtail. Thanks for your time.
Thanks wirenut.
Bocolo is offline   Reply With Quote
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Leviton 8599 GFCI wiring issues Ultrarunner2017 Electrical 4 02-06-2009 08:53 AM
Older wiring question... PirateKatz Electrical 8 11-25-2008 10:11 AM
receptacles have no power, im at a loss reds_21 Electrical 3 10-05-2008 10:49 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
