Wiring Receptacles - Electrical - DIY Chatroom Home Improvement Forum
Old 04-02-2013, 01:59 PM   #1
wiring receptacles
Hello everyone,
I am new to this site and I need your help.
I need to wire up some receptacles. On one receptacle box I have a 12/3 and a 12/2 romex coming thru. On another receptacle box I have two 12/3 romex coming thru. Last but not least I need to wire 2 receptacles with only a 12/3 romex coming thru the box. None of these are connected to the breaker box yet. I am trying to help my electrician friend who had a family emergency. I will leave the breaker box to him.
Thanks in advance,
Ray
chonchonater is offline   Reply With Quote
Old 04-02-2013, 03:26 PM   #2
Originally Posted by chonchonater View Post
Hello everyone,
Thanks in advance,
Ray
He will hate you for it!
Explain 12/3 vs 12/2 first. What you may have is switch controlled recpts.
64pvolvo1800 is offline   Reply With Quote
Old 04-02-2013, 03:36 PM   #3
wiring receptacles
He is a good friend of mine the 12/3 romex has a red,black,white, and ground wire, The 12/2 romex has a black,white,and ground wire. I would tell him exactly what I did when I wired them up also I would take a picture with my phone.
Ray
Old 04-02-2013, 03:41 PM   #4
Ray
Are these recpts tied to each other in a string? What was the intent of the recpts/room and why the rewire? Maybe that'll help us understand the 12/3. I could see it on one for a switched outlet. Also, if its a switched outlet they usually only control one and the center jumper must be cut.
Old 04-02-2013, 03:51 PM   #5
wiring receptacles
Yes they are, rooms are being remodeled old sheetrock has been removed.
Old 04-02-2013, 04:02 PM   #6
Was this a freebie favor for a friend? Maybe he just had some extra 12/3 and used it. Is the 12/2 going back to the breaker?
Old 04-02-2013, 04:14 PM   #7
wiring receptacles
Yes it is, and no the 12/2 is not going back to the box. He is a licensed electrician.
Old 04-02-2013, 04:21 PM   #8
Electrical Contractor
jbfan's Avatar
Rewards Points: 488
There can be many reasons why you have 12/3 and 12/2 in a box.
Without knowing what he intended to do, you will cause him more problems than help him.
jbfan is online now   Reply With Quote
Old 04-02-2013, 04:42 PM   #9
wiring receptacles
I think you are right. What about wiring an outlet with 2 12/3 lines?
Old 04-02-2013, 05:00 PM   #10
An old Tradesmen
Rewards Points: 7,370
Moved to Electrical forum.
Old 04-02-2013, 05:04 PM   #11
jbfan's Avatar
Rewards Points: 488
Same thing.
Is he intending to switch one and then feed through to another and switch it also?
Old 04-02-2013, 05:14 PM   #12
wiring receptacles
Box 1 has two 12/3 lines coming into it and is feeding box 2,Box 2 is feeding box 3,but has a 12/2 line going to the last box.
Knob & Tube Wiring? cbzdel Electrical 8 08-17-2012 06:33 AM
Surface Mounted Receptacles - Big Bulge? HandyMartin Electrical 13 08-10-2010 04:06 PM
Wiring Receptacles Bocolo Electrical 17 03-02-2009 05:01 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
