Old 12-01-2009, 09:46 PM   #1
wiring receptacle form light switch
Hello,
have a problem and questions. Need to add a new receptacle but the only line available to tap from is a switch light with just three wires black, white and ground. How can I do this? I dont want the switch to control the receptacle. Thank you
olazu is offline   Reply With Quote
Old 12-01-2009, 09:48 PM   #2
Xtreme DIY'r
If there are only 3 wires it is a hot switch loop & you can't pull power for an outlet
You don't have a neutral, just a hot & ground
Old 12-01-2009, 09:58 PM   #3
Thank you for your information
I was also trying to tap it from junction box that had a red and white pigtailed and two blacks pigtailed. I connected the white to the white and red and the black to the other blacks ones, but when I plugged the tv it looked like there wasn't enough power coming from the receptacle since the tv turn on but it was like coming and going
Old 12-01-2009, 11:13 PM   #4
Licensed Electrician
Magnettica's Avatar
Send a message via Yahoo to Magnettica
Red and white pigtailed? Hmmm. I'm a pro and I don't see that very often.
I would suggest plugging in a lamp first before testing your handy work using a television.
Union County, NJ, Licensed Electrician
Magnettica is offline   Reply With Quote
Old 12-01-2009, 11:50 PM   #5
Xtreme DIY'r
Yeah..someone else used a TV as a test & they were off to buy a new TV after it was fried by improper wiring
Red is usually hot, not tied to neutral
Or its for connecting smokes together - signal wire
I'd verify what's wired where & how before you do anything
That takes eyes on the issue, looking in the panel & other outlest/switches to see what the heck they did
Any 3 way switches ?
Old 12-02-2009, 03:26 PM   #6
the connection was made to add a bathroom fan. we had a light switch with a receptacle combo/he added another switch to control the fan
Old 12-02-2009, 10:45 PM   #7
was it connected to a GFI?
kegkiller is offline   Reply With Quote
Old 12-03-2009, 08:14 AM   #8
No it wasn't
Old 12-03-2009, 10:10 PM   #9
Scared Electrician
Saturday Cowboy's Avatar
Im guessing we are looking at another switch leg here, not a neutral.
And so it goes, R
Saturday Cowboy is offline   Reply With Quote
Wiring a single pole switch with a pilot light gabriel246 Electrical 5 10-31-2009 07:03 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
wiring ceiling fan to light switch cshsr Electrical 10 07-20-2009 05:08 PM
wiring an existing light to a new exhaust fan with one switch konroy Electrical 1 04-28-2009 12:37 PM
recessed lighting wiring to 3way switch DIY4EVER Electrical 1 07-12-2007 02:35 PM
