Wiring A Range Plug Mid 80,s Home - Electrical - DIY Chatroom Home Improvement Forum
Old 04-02-2011, 05:03 PM   #1
wiring a range plug mid 80,s home
I have a mid 80'S home and the old range was hard wired. i have bought a 4 wire outlet to fit the new range plug. the wiring from the house only has 3 wires. 2 black that i am assuming are hot. and one bare silver wire same gauge that i am assuming neutral. the four wire outlet has a spot for a ground. can i hook up the 4 wire outlet without the ground coming from breaker?
dave75 is offline   Reply With Quote
Old 04-02-2011, 05:53 PM   #2
Licensed electrician
Rewards Points: 1,010
You will need to get a 3 prong receptacle and cord set.
Old 04-03-2011, 08:29 AM   #3
Rewards Points: 530
Jim, why can he not just make sure the range has a ground strap from the range to the middle lug and hardwire it like it was, disregarding the green grnd wire?
Moving Electric Range Plug dmartins Electrical 3 11-23-2010 08:48 AM
Tight home needs a range hood katdixon58 HVAC 14 02-20-2010 11:02 PM
New Range Wiring c086473 Electrical 4 03-11-2008 09:50 PM
changing a range outlet or plug marty7 Electrical 9 12-17-2007 11:11 PM
Home, home and the range! ...A dimensional query. Hushpuppy Carpentry 4 05-26-2006 07:23 PM
