Old 08-08-2012, 09:43 AM   #1
Wiring Questions
Alright... I have a 2-gang electrical box, one switch controls the ceiling fan and the other switch controls two outlets (so four plugs). I've been remodeling my house and just installed some rope light in some crown molding. I connected the two rope light together and ran the romex wire down to the box. I also bought a new double switch (which will have three switches in the box). Where am I suppose to go with this to get my rope light to work? The original wires that's in the electrical box right now is a black and black for the ceiling fan and a red and black for the outlets. People said to keep all the outlets hot and connect the black and red in the outlets so I could use that loop. Does that sound right? I opened up my outlets and saw two white wires, two red wires, and two blacks wires. Which one do I connect? Hopefully that make sense to someone.
Additional information: the rope light brand is Hampton Bay and the original plug has a fuse. Does that matter?
Tuan-n88 is offline   Reply With Quote
Old 08-08-2012, 10:09 AM   #2
"So I Re-Wired It"
MisterZ's Avatar
Wiring Questions
Pretty sure these are supposed to be plugged in and use the controls that came with it.
Wiring a device against manufacturer design can be highly dangerous.
If this uses an outlet, plug them into a switched outelt.
If they can be hard wired, what do the instructions say?
Knowledge is Power, but 240v can Keel You!!
MisterZ is offline   Reply With Quote
Tags
double switch, light switch, outlet, rope light, wiring
Upgraded loadcenter wiring questions Johnd85053 Electrical 9 02-05-2012 06:35 PM
Questions about wiring a line voltage thermostat thinksincode Electrical 15 01-12-2012 09:50 PM
Sub panel wiring and voltage drop questions CPF Electrical 6 11-30-2011 08:52 AM
Wiring questions stalesweetness Electrical 0 11-21-2011 10:59 PM
Kitchen Wiring Questions Chazbe Electrical 22 04-11-2008 05:06 PM
