Wiring Question - Two Lights With One Switch... - Electrical - DIY Chatroom Home Improvement Forum
Old 12-27-2010, 09:00 PM   #1
Wiring question - two lights with one switch...
I recently moved into a house that has two exterior lights on the front that don't work. (yes I checked the bulbs!)
Luckily I have some limited access to the ceiling and can track some of the wires. From what I can see, there is power entering the switch box, and a 14/2 cable going from the switch box to each light. I am puzzled because from what I have read, I thought that there should be a14/2 between the lights and a 14/2 from the switch to one light only.
In the switch box, the black power is connected to one side of the switch, and the two blacks (from each light) are maretted and attached to the other side of the switch. All three whites are tied together.
The only other option I can think of is that it might be the fixture itself but it's cold herd and I don't want to be outside!
Cleon26 is offline   Reply With Quote
Old 12-28-2010, 12:34 AM   #2
Scared Electrician
Saturday Cowboy's Avatar
well this sounds wired propery. checked the breakers? check for voltage at switch. If good at switch then problem is at lights. begin looking for bad connections.
Saturday Cowboy is offline   Reply With Quote
Old 12-28-2010, 05:57 AM   #3
Electrical Contractor
kbsparky's Avatar
Bad switch?
If both lights quit, then look either at the switch itself, or the power supply going to it.
-KB
Old 12-28-2010, 09:09 AM   #4
Rewards Points: 1,542
Power to the switch and from there separate cables to each light ...
Is just as good as ...
Power to the switch, then one cable to one light where there is a cable to the other light.
Except in the first case the box where the switch is and everything comes together will be more crowded and in most cases the box would have to be larger compared with the second case.
Wiring an Intermatic Wall Timer in a three way switch aitutaki98 Electrical 6 07-23-2011 11:43 AM
4 wire occupancy switch wiring.. FLASHING lights?? darin00 Electrical 3 12-18-2010 07:38 AM
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 02:17 AM
wiring several recessed lights from 1 switch raineydr Electrical 14 03-15-2010 08:52 AM
4 way switch wiring ponch37300 Electrical 9 02-16-2009 09:58 AM
