Wiring Question For Camper - Electrical - DIY Chatroom Home Improvement Forum
Old 07-28-2009, 02:57 PM   #1
Wiring question for camper
Hello,
I am double-checking to refresh my memory. I have two posts that I need to add electric receptacles for campers on my campground, and I have one light pole that I want to add light and one 110v receptacle for a pop-up camper or one that require only 110v power (20amp).
Post #1 is exactly 210 feet away from electric box (panel) so I will need #8 underground wire for 30amp, correct? What about 110v/20amp underground wire? #12? #10?
Post #2 is exactly 240 feet away. #8 again for 30amp and 12 for 110v?
The light pole is 330' away so this is the length I will need to set up for one 110v/20amp receptacle and then add probably 30' on top of it for amber night light. What # of wire do I use for this?
I am just trying to get right wiring info so I can calculate the price before I can propose "ballpark price" to my family prior to getting licensed electrician to help install. I have installed electric for my campground on family property last year with no trouble (used licensed electrican and worked under his supervisor/inspection). I paid for it last year and now campground is starting to show some promising so my family agreed to pitch in to finish the other half.
Many thanks for replying!
wkheathjr is offline   Reply With Quote
Old 07-28-2009, 03:20 PM   #2
Rewards Points: 78
Why not just let the electrician quote the complete job? Your price and his will not be the same.
Old 07-28-2009, 03:46 PM   #3
Because I buy the materials and install everything myself. I just tell him what I will do and show him the supplies. Once I have his approval, he goes to get the permit for me in his name and I do the whole work. Then when I am done, I call him first for inspection. When he is satisfied, he calls the inspector himself. Then he charges me $400 for using his license.
Old 07-28-2009, 05:15 PM   #4
Please disregard.. got the answer.. thanks!
Attic wiring question everyman Electrical 4 07-07-2009 10:47 AM
Quick wiring question with HVAC Gjtrafl Electrical 4 06-25-2009 03:03 PM
carrier 48ss-042 wiring Question bekind42 HVAC 3 06-15-2009 06:54 PM
wiring recessed lights question. SubSailor Electrical 2 02-25-2008 01:39 PM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 10:10 PM
