Wiring Question About Elect Heater - Electrical - DIY Chatroom Home Improvement Forum
Old 12-03-2012, 07:32 AM   #1
Rewards Points: 85
Hi again!
I would like to install a baseboard heater in my mothers bathroom. Her place is an old Victorian about 120 y.o with oil heat. The bathroom is always chilly in the am and living in PA it's the norm this time of year.
Was thinking a 27" or 36" heater between 500 to 750 watts.
My questions are, can I get waway with 12-2 on the wiring or should I go with a thicker wire? Also, should I add a GFCI breaker on the dedicated line? I'm thinking 120v unless you think 220v would be better?
Thanks!
JohnC20 is offline   Reply With Quote
Old 12-03-2012, 08:25 AM   #2
joed's Avatar
Rewards Points: 12,008
For that low wattage you could get away with 14/2 cable and a 15 amp circuit. 750 watts is only 6.25 amps.
Old 12-03-2012, 08:29 AM   #3
Rewards Points: 85
Funny, I realized that after the post. Thanks! Should I throw it on a GFCI breaker?
Old 12-03-2012, 08:33 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
You can go up to 2400 watts on a 20 amp 120 volt circuit (#12 cable). GFCI not required by NEC but read manufacturers instructions.
700 watts is pretty small, I would go with 1500 watts. You can always turn it down.
Coastal South Carolina
Old 12-03-2012, 03:19 PM   #5
Julius793's Avatar
That would be incorrect in regard to a heater, because you forgot that by a continuous load you can only fill the circuit to 80%
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 12-03-2012, 03:22 PM   #6
Semi-Pro Electro-Geek
Rewards Points: 2,902
Not for permanently installed electric heat, since it's defined as a continuous load regardless of how it's actually used. The 80% rule applies, so 1920W max on a 20A circuit. I would install a 1500W heater with a wall mounted thermostat and timer.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
wiring question bmancanfly Electrical 18 12-04-2010 01:01 PM
Heater wiring and breaker size question Tmb9862 Electrical 12 12-26-2009 04:27 PM
Garage heater venting question brill0724 HVAC 1 12-09-2009 08:06 PM
Basement wiring question kupalino Electrical 8 11-14-2009 10:25 AM
240/208 Heater wiring Question fburke Electrical 2 06-20-2005 01:09 PM
