#16 |
" Euro " electrician
wiring question
The issue you will run into it is the way the majtory of resdentail water heaters they use single pole thermosat on both beside the upper unit it will have SPDT upper thermosat so when the tank is cold it will run upper thermosat until it get warm then switch over to lower element that where pretty good percentage of time of element running.
that why I mention current transfomer reading so it will read the current instead of voltage which plain jane hourmeter will read. Very rare to see any resdential water heater have legit double pole thermosat for both upper and lower elements. Merci. Marc |
#17 |
wiring question
Thanks French.
Not sure I completely understand what your saying. But I am finding that the upper element is not running nearly as much as I thought it would. Apparently, the lower element does most of the work. I'll find out when I switch the meter over the the lower element. |
#18 |
Electrical Contractor
wiring question
The lower element heats 90% of your hot water needs.
The upper element rarely will come on, only when most of your hot water supply has been depleted. A watt-hour meter would be better to use to determine the exact usage of an appliance. Here is a kit on ebaY that includes both a meter and a socket.
-KB Life is uncertain -- eat dessert first!! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#19 |
wiring question
Thanks sparky. I wish I had seen that a couple of weeks ago.
It's not much more that what I paid for my little meter. Oh well, you live and learn. |
| Display Modes | |
| Question about AFCI and Ontario code as well as some other general wiring queries | drunken0monkey | Electrical | 5 | 06-15-2010 10:49 AM |
| Yet another subpanel wiring question | Chris_M | Electrical | 6 | 06-10-2010 06:12 PM |
| mini split Wiring question??? | mjebril | HVAC | 5 | 08-02-2009 07:31 PM |
| Attic wiring question | everyman | Electrical | 4 | 07-07-2009 10:47 AM |
| Trane Heat Pump tstat replacement with Honeywell prog - wiring question | sep23 | HVAC | 2 | 10-20-2006 10:10 PM |
