Wiring Question - Electrical - DIY Chatroom Home Improvement Forum
Old 07-16-2010, 04:49 PM   #1
Home owner
Bootz's Avatar
Rewards Points: 150
Send a message via AIM to Bootz
Wiring question
Okay So we moved into this condo and there are a couple of things the lady would like to do. One of them is put some kind of lighting on top of the ledges around the kitchen area. There is a light switch right on the wall before going into the kitchen with two light switches... one works the light inside the kitchen and another does nothing... How would I go about wiring the electrical switch for the lighting to be installed or is there a place i could reference and do you all have any recommendations on lights that would be modern or better to install on top of the ledge?
Okay I will try to illustrate this the best i can because I do not know how to do the photos yet
/ <--- Slant of ceiling
/_______ <--- ledge
//////////| Down to kitchen
_______|
Bootz is offline   Reply With Quote
Old 07-16-2010, 05:34 PM   #2
Master Electrician
Rewards Points: 3,746
Have you looked up there. Perhaps there is a receptacle controlled by the phantom switch.
brric is offline   Reply With Quote
Old 07-16-2010, 06:29 PM   #3
I would fist verify that the switch which controls nothing does infact control nothing, it's very odd. Possibilities for it are an external light, an outlet or 1/2 of an outlet, or perhaps more sinister such as a buried outlet. By the way, how old is the condo?
As far as the lighting, I personnaly dislike lighting up on the ledge. It illuminates the ceiling very well, but not so much anything else. I would personally consider updating the existing light fixtures to a better fixture or a track lighting system before putting lights up on the ledge, that might just be me though.
Troglodyte is offline   Reply With Quote
Question about AFCI and Ontario code as well as some other general wiring queries drunken0monkey Electrical 5 06-15-2010 10:49 AM
Yet another subpanel wiring question Chris_M Electrical 6 06-10-2010 06:12 PM
mini split Wiring question??? mjebril HVAC 5 08-02-2009 07:31 PM
Attic wiring question everyman Electrical 4 07-07-2009 10:47 AM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 10:10 PM
