Wiring Question - Electrical - DIY Chatroom Home Improvement Forum
Old 11-18-2009, 01:50 PM   #1
wiring question
Hello,
I have an existing switch for a light and I would like to add an outlet between the switch and the light.
I have 1 line coming into the switch with a black, white, and bare wire.
I cut the line short at the outlet (which is right below the switch). I then ran a new line from the outlet up to the switch.
I piggybacked the black wires and ran one to the switch and one to the outlet. I then connected both white wires together.
The switch is now working fine, but I am getting no power at the outlet. I would like to have continuous power at the outlet regardless of the switch position.
I assume the problem is the lack of a white wire going to the outlet. Could anyone tell me how I can get this working?
Thanks for any thoughts.
dinger21 is offline   Reply With Quote
Old 11-18-2009, 02:01 PM   #2
Licensed Pro
If you only have one set of wires at the switch... black, white, bare.. this is a switch loop and there is no neutral available. The white in this case is hot to the switch and the black is the switched hot to the light. You will need to find another power source for the new receptacle that has hot and neutral available. It won't work with what you have now.
Attic wiring question everyman Electrical 4 07-07-2009 09:47 AM
Quick wiring question with HVAC Gjtrafl Electrical 4 06-25-2009 02:03 PM
carrier 48ss-042 wiring Question bekind42 HVAC 3 06-15-2009 05:54 PM
wiring recessed lights question. SubSailor Electrical 2 02-25-2008 12:39 PM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 09:10 PM
