Wiring Question - Electrical - DIY Chatroom Home Improvement Forum
Old 08-31-2009, 08:21 PM   #1
wiring question
can you run a LED night light bulb on a low voltage line like 12volts or is it not enough power?
Hatter is offline   Reply With Quote
Old 08-31-2009, 08:29 PM   #2
Most night lights are meant to run off of 120v
You would need to check the specs on the night light you buy
Running a 120v light on a 12v line would not work
Old 09-01-2009, 07:54 PM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Hatter, Welcome to the forum
I agree with Scuba
This circuit diagram might help:
http://en.wikipedia.org/wiki/LED_circuit
Note that in the circuit diagram a resistor is used to drop the voltage down to the 2V-4V Led operating voltage (depends on the Led color) Blue and White Leds are in the 4V range, reds and yellows more like 2V.
Since just using a resistor is extremely uneconomical from a power standpoint multiple LEDs are connected in series with or without a Led Driver circuit that limits current.
Disclaimer
& Stay Safe
.....Bob Lavery
Attic wiring question everyman Electrical 4 07-07-2009 10:47 AM
Quick wiring question with HVAC Gjtrafl Electrical 4 06-25-2009 03:03 PM
carrier 48ss-042 wiring Question bekind42 HVAC 3 06-15-2009 06:54 PM
wiring recessed lights question. SubSailor Electrical 2 02-25-2008 01:39 PM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 10:10 PM
