Wiring Question.... - Electrical - DIY Chatroom Home Improvement Forum
Old 04-26-2009, 03:32 PM   #1
Wiring Question....
Hi guys, I have a couple questions and would like to see if anyone here can help me.
First off I live in an apartment with a attached garage. So I CAN NOT modify any of the electrical stuff.
I picked up an oven and need to try to use the same outlet as I do my compressor. I know I would only be able to use one at a time BUT thats ok.
Ok now for about a month or so I have my compressor wired into a 35 foot 10-3 cable that I run into the house and plug it into my dryer socket. It works PERFECTLY fine. Now what I would like to do is take that cord that plugs into the dryer outlet and add another outlet on the end of it. Another one that looks like the dryer plug on the wall. So all I would have to do is plug in either the compressor or the oven. I could only use one at a time but that is fine.
What do you guys think? Will that work?
RJBrown is offline   Reply With Quote
Old 04-26-2009, 08:24 PM   #2
Rewards Points: 150
Send a message via AIM to Bocolo
Are you talking about making an extension cord?
One Pound of Knowledge Requires Ten Pounds of Common Sense In Order To Be Useful
Bocolo is offline   Reply With Quote
Old 04-26-2009, 08:32 PM   #3
What is the rating of the oven?
What is the rating of the dryer?
Breaker size?
Wire size to the dryer?
Old 04-26-2009, 08:33 PM   #4
Yes basically a 35 foot cable with one side male and one side female. So I can switch from my compressor to my oven.
30amp breaker
10-3 cable
not sure rating of oven
compressor runs off the breaker just fine.
Old 04-26-2009, 08:36 PM   #5
If you don't know the rating of the oven then we can't answer your question
Old 04-26-2009, 11:56 PM   #6
A single oven is typically a 30 amp circuit.
You need to know that, just like your compressor, it's not a legal/safe wiring method. Extension cords generally are not.
220/221 is offline   Reply With Quote
Question on generator wiring mdalli Electrical 35 10-05-2011 08:45 PM
Wiring Question bahaisamurai Electrical 3 02-22-2009 12:06 PM
wiring recessed lights question. SubSailor Electrical 2 02-25-2008 01:39 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 10:10 PM
