Wiring Question - Electrical - DIY Chatroom Home Improvement Forum
Old 10-29-2008, 07:18 PM   #1
Wiring Question
Hello there, im looking for a little help.
Im planning on building a box, which is going to consist of a row of about 7 or 8 75w flood lights, kind of similar to the Red/Yellow/Green lights you would see at a dragrace track...except they will all go on/off at the same time.
What would be the best way to wire them?
Thanks.
ryrypizza is offline   Reply With Quote
Old 10-29-2008, 07:24 PM   #2
Electrician
Thanks.
I would just use surface bell boxes piped together with EMT and a premade cord and a cord connector in the last box.
chris75 is offline   Reply With Quote
Old 10-29-2008, 10:23 PM   #3
Hey thanks for getting back to me!!
By premade wire, what exactly do you mean? Do you have an example you could show me?
Also were you suggesting they be wired in series?
I have some electrical knowledge,im in now way a specialist, but im a real quick learner.
Old 10-30-2008, 12:16 AM   #4
W/P j box
Hub cover
lamp holder
Connect the boxes with threaded nipples.
Run a pigtail into the back of the first box.
Attach the green wire to the ground screw on the first box. Attach black/whire wires thru boxes to lights.
Attach a deck flange via threaded nipple to the bottom box and screw it down to something big enough to support your light set.
220/221 is offline   Reply With Quote
Old 10-30-2008, 05:24 AM   #5
the Musigician
DangerMouse's Avatar
running series or parallel.... one way if one light burns out, they all go, the other, if one dies, the others stay lit. pretty sure you'd prefer the latter.... with bulbs in a box, you'd have heat buildup to consider as well. perhaps if you drew up a sketch of what you want to build and post it, we could help more. =o)
DM
Old 10-30-2008, 02:45 PM   #6
All 120V lighting will be parallel
Old 10-30-2008, 08:13 PM   #7
Thanks for all the help. Yeah the only advantage to the series is..its easier, but yeah I definitely don't want any lights to go out and kill the rest.
As far as the box goes the lights will be on the outside, so there really wont be any place for the heat to build up.
Thanks for the help guys. If i have any more questions ill ask away.
Old 10-31-2008, 12:19 AM   #8
Electrician's Helper
Pudge565's Avatar
Rewards Points: 150
Send a message via AIM to Pudge565
This is not true you can wire it as series. Not the correct way and lights will be dim the more lights the more dim.
Pudge565 is offline   Reply With Quote
Old 10-31-2008, 03:42 AM   #9
the Musigician
thank you for that Pudge.... some might read this and believe it to be true. strings of Christmas lights comes to mind..........
DM
Old 10-31-2008, 05:57 AM   #10
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,990
OK, so let's get technical. All 120v lighting wired correctly will be in parallel.
That's because it IS true.
If you wire in series then it is NOT 120v lighting anymore.
Old 10-31-2008, 06:04 AM   #11
the Musigician
thanks for that clarification petey!
DM
Old 10-31-2008, 04:40 PM   #12
Electrician
You guys scare the hell out of me.
Old 10-31-2008, 10:50 PM   #13
Pudge565's Avatar
Rewards Points: 150
You know I never did think about that part. Thanks for that petey. Now I look like a .
Old 11-01-2008, 06:41 AM   #14
An old Tradesmen
Rewards Points: 8,142
8-120 volt, 75 watt lights wired in series, would only give you about 10 watts of lighting.
Old 11-03-2008, 11:29 AM   #15
Should every light have its own cord cap, or can I group them together? Like say 2 groups of 4 lights, or 4 groups of 2 lights, with each group splitting off from a central line with its own end cap.
Question on generator wiring mdalli Electrical 35 10-05-2011 07:45 PM
Question with wiring up a flood light. SuperAkuma Electrical 6 09-20-2008 10:58 AM
wiring recessed lights question. SubSailor Electrical 2 02-25-2008 12:39 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 09:10 PM
