Wiring Question - Electrical - DIY Chatroom Home Improvement Forum
Old 12-17-2012, 02:44 PM   #1
Talking
Wiring Question
Hello,
I know this has probably been covered somewhere on this forum but I cant seem to find it. I currently have a room with a plug that is powered by a switch and wanted to covert it so that the switch will power an overhead light.
Here are the details:
Single pole switch
Top connector - white wire
Bottom Connector - black wire
and of course the (bare) ground wire is attached to the ground screw
Outlet
right side (gold screws) black wire on each
left side (silver screws) white wire on each
and of course the (bare) ground wire attached o the green ground screw.
any help with this would be very much appreciated.
Thank you,
Chris
cliacos01 is offline   Reply With Quote
Old 12-17-2012, 03:02 PM   #2
Rewards Points: 2,516
Originally Posted by cliacos01 View Post
Hello,
You want the switch to power a light and the outlet or just power the light?
If just power the light, what is your intention with the outlet?
hammerlane is offline   Reply With Quote
Old 12-17-2012, 03:21 PM   #3
Re: wiring question
Sorry I should been more specific. I would like the switch to power just the light and the plug to be a regular plug if possible. Or it could still be powered by the switch, whatever is easier (only the bottom plug is powered by the switch)
Old 12-17-2012, 04:26 PM   #4
TTW
TTW's Avatar
Is this a new light that you are installing and can you run a wire from the outlet junction box to the light?
On a duplex receptacle, there is a tab that connects the screws on each side (the two dark together and the two silver together).
When an electrician wants to switch one outlet, normally he will break the tab only on the hot side, running one always hot to one screw ; and one switched hot to the other screw (on the same side).
You will probably have to remove the switched hot and jumper the always hot between the two screws with pigtails.
Then take the switched hot to the light. Neutrals connected together.
Make sure this is all on one breaker!
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 12-17-2012, 04:38 PM   #5
It will a new light. The attic is right above the room so it should be easy eunning the wires with my snake into the atyic. Thanks for the help
Old 12-17-2012, 04:45 PM   #6
TTW
TTW's Avatar
Spend $2.50 on a new plug with the tabs intact. It will save some pigtailing.
Also it is proper to mark the white wire at the switch with black tape to identify it as a hot conductor, and on the other end as well.
208V/3 Phase Wiring Question efalcon1 Electrical 12 09-28-2012 11:22 AM
Outdoor Wiring Question OKDrew63 Electrical 30 08-14-2012 11:25 PM
Adding 2 outlets in the middle of a series of outlets - wiring question Evan55 Electrical 7 06-14-2012 09:43 AM
Attic wiring question everyman Electrical 4 07-07-2009 09:47 AM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 09:10 PM
