Wiring Question - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-17-2012, 01:02 PM   #16
Rewards Points: 1,452
The original diagram, with neutrals separated in the S3-S4 box, is correct.
Old 12-17-2012, 01:53 PM   #17
Rewards Points: 2,516
Imagine that the junction box was not there and the source cable as you call it goes into the S3/S4 location. Why would there be a need run another neutral from S1/S2 location back to the S3/S4 location?
hammerlane is offline   Reply With Quote
Old 12-17-2012, 01:56 PM   #18
BUT....At S3/S4, having all neutrals under one wire nut is not incorrect along with eliminating the neutral from the S1/S2 location to the S3/S4 location.
Also looked more closely at Allans post #14...I could live with that also.
Old 12-17-2012, 02:39 PM   #19
Rewards Points: 202
Is one way more preferred?
That is--using the existing 3 conductor cable from S2 to S3, coding the white for traveler and bringing in power to S3 box rather than pigtailing from S1's power feed as I currently have it?
obviously one would be preferred if it were to save on cable, but otherwise?
benleef is offline   Reply With Quote
208V/3 Phase Wiring Question efalcon1 Electrical 12 09-28-2012 12:22 PM
Outdoor Wiring Question OKDrew63 Electrical 30 08-15-2012 12:25 AM
Adding 2 outlets in the middle of a series of outlets - wiring question Evan55 Electrical 7 06-14-2012 10:43 AM
Attic wiring question everyman Electrical 4 07-07-2009 10:47 AM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 10:10 PM
