Wiring Question - Electrical - DIY Chatroom Home Improvement Forum
Old 12-17-2012, 08:39 AM   #1
Rewards Points: 202
Wiring question
I'm in the process of adding some lights. See diagram below.
My question is. In the switch box for S3 and S4.... Do I connect all the neutrals together? This is all the same circuit, so I'm pretty sure that I do, but I just wanted to make sure.
Thanks!
benleef is offline   Reply With Quote
Old 12-17-2012, 08:42 AM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
No. Keep them seperate.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 12-17-2012, 09:01 AM   #3
Rewards Points: 2,516
Those neutrals can all be wire nutted in the location with switch 3 and 4. You could actually eliminate one of the neutrals I have marked with a green "X".
What is the "floating" red wire for at the junction box and the switch 1 and 2 location
hammerlane is offline   Reply With Quote
Old 12-17-2012, 09:02 AM   #4
Rewards Points: 202
What is the reason? Is case there ends up being a loose or open neutral in the S1&S2 box?
Thanks!
Old 12-17-2012, 09:11 AM   #5
Licensed Pro
Why do the junction box? Route the power to the S1-S2 box, then continue to the S3-S4 box along with the 3-way wiring. You end up with an extra neutral wire, but unless you use 4 conductor cable or conduit, that can't be helped.
Old 12-17-2012, 09:15 AM   #6
Rewards Points: 202
The red wire is just an extra wire. When I first moved in (and knew nothing of wiring), I had a light installed by an electrician and he ran 14/3 to S1, which controlled L1 and two other lights which I am removing. Now I just have the reds capped.
Old 12-17-2012, 09:21 AM   #7
Rewards Points: 202
S1 and L1 already existed. the 14/3 wire from the junction box terminated at an old junction box, which I found was actually powered by a 20 Amp breaker. The run from Panel to S1 is the longest run, so I just ran new power to new junction box close to old one--on proper 15Amp circuit.
Old 12-17-2012, 09:55 AM   #8
Rewards Points: 1,538
To avoid confusion at a later date and also prevent undesirable neutral sharing should the branch circuit configuration and breaker assignments be changed, when two power feeds (cables, groupings of conductors) with neutrals enter the same box (here, S3-S4), do not combine the neutrals. In addition, the neutral for each downstream continuation or subcircuit is to be connected only to the neutral of the incoming cable whose hot wire powers that continuation.
For the diagram, keep everything as shown.
Light #1 is a typical source - switch (S1) - light configuration.
Light #2 is a typical 3 way source - switch (S2) - switch (S3) - light configuration.
Lights #3 and #4 are in a typical source - switch (S4) -light (L3) - light (S4) configuration.
AllanJ is online now   Reply With Quote
The Following User Says Thank You to AllanJ For This Useful Post:
benleef (12-17-2012)
Old 12-17-2012, 10:12 AM   #9
Rewards Points: 202
Originally Posted by AllanJ View Post
To avoid confusion at a later date and also prevent undesirable neutral sharing should the branch circuit configuration and breaker assignments be changed, when two power feeds (cables, groupings of conductors) with neutrals enter the same box, do not combine the neutrals. In addition, the neutral for each downstream continuation or subcircuit is to be connected only to the neutral of the incoming cable whose hot wire powers that continuation.
For the above diagram, keep everything as shown.
Thanks for the help! That makes sense. So, if at the later date the source circuit for S4-L3-L4 was ever changed, this removes the chance for error that the neutrals in box for S3/S4 would be connected even though on separate circuits.
Old 12-17-2012, 10:28 AM   #10
There is nothing wrong with this:
Old 12-17-2012, 10:35 AM   #11
Rewards Points: 202
OK. I already ran the wire from S2 to S3, including a neutral wire. Actually I already ran all the wiring except for that from S4 to L3 and L4.
In hindsight I guess I could have saved a few bucks and only ran 2 conductors from S2 to S3
Old 12-17-2012, 10:44 AM   #12
The cable from S2 to S3 are traveller wires. No need to carry a neutral with that pair as there is already a neutral at the S3/S4 location.
whats done is done.
The Following User Says Thank You to hammerlane For This Useful Post:
Old 12-17-2012, 11:00 AM   #13
Rewards Points: 202
whats done is done.
I decided to add S4 later, so I guess at the time I was doing it correctly--carrying the neutral from S2 to S3 to L2.
Old 12-17-2012, 11:07 AM   #14
Because the OP has already strung the wires, the following is for eavesdroppers only (click picture to enlarge).
Old 12-17-2012, 11:41 AM   #15
Rewards Points: 202
Just to be sure, as you laid out above, the way I have it is OK, just keep the neutrals separate in box of S3/S4?
208V/3 Phase Wiring Question efalcon1 Electrical 12 09-28-2012 11:22 AM
Outdoor Wiring Question OKDrew63 Electrical 30 08-14-2012 11:25 PM
Adding 2 outlets in the middle of a series of outlets - wiring question Evan55 Electrical 7 06-14-2012 09:43 AM
Attic wiring question everyman Electrical 4 07-07-2009 09:47 AM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 09:10 PM
