Wiring Question? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-21-2011, 01:48 PM   #1
Wiring question?
Okay, let's see if I can explain this so people will understand me. I am going to wire a light switch to some new lights that I have in my garage attic which I have no problem doing and understand but have a question about an existing junction box that was in the attic.
In the box was the power supply cable. Then there were two more cables that were coming in from the switch that had the blacks and whites. So the power cable was supplying the power to the switch on the one set and the switch was supplying the power to the light on the other. The black line from the power cable was connected to the black power on the cable that ran to the switch. The white from the power was connected to the white neutrals in the box. The black line running up from the switch was connected to the light and the white from the light was also connected to the whites. My problem though is that the white coming up from the switch was connected to the black power coming in and the black power going down to the switch. Is that right?
ingeborgdot is offline   Reply With Quote
Old 05-21-2011, 02:15 PM   #2
Rewards Points: 320
It is hard to follow exactly what you have there from just the description. Can you post a picture or a diagram?
teamo is offline   Reply With Quote
Old 05-21-2011, 05:58 PM   #3
Yep, I figured out what it was. The switch only had one cable going in to the switch. The other cable I thought was going into the switch was actually going to a junction box. I got it all wired and it works great. Thanks.
Old 05-22-2011, 01:44 AM   #4
Scared Electrician
Saturday Cowboy's Avatar
Back on Black!
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Question about AFCI and Ontario code as well as some other general wiring queries drunken0monkey Electrical 5 06-15-2010 10:49 AM
Yet another subpanel wiring question Chris_M Electrical 6 06-10-2010 06:12 PM
mini split Wiring question??? mjebril HVAC 5 08-02-2009 07:31 PM
Attic wiring question everyman Electrical 4 07-07-2009 10:47 AM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 10:10 PM
