Wiring Problems - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-26-2009, 06:25 PM   #16
Bigplanz's Avatar
Rewards Points: 996
You can bury UF, as long as it's 24 inches down. I think your subpanel installation was a touch too much for your level of experience. I always leave stuff like that to an electrician, and recommend others do as well unless they are a 'qualified person' as per the NEC. I feel comfortable doing some things, but nothing like that. Know your limits, and all that.
Bigplanz is offline   Reply With Quote
Old 04-26-2009, 06:29 PM   #17
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,990
Originally Posted by sunici View Post
As for the non-GFCI outlets in the kitchen, they were not protected. The one circuit (#10 breaker) had three outlets, none of which were GFCI. They are more than 6' from the sink,
This was code complaint when you house was built. There is nothing wrong with upgrading now.
but the fridge is on one of those outlets and it has a water line for the ice maker.
No matter. It still does not need GFI protection, nor would I want it.
The third kitchen circuit (#1 breaker) consists of one outlet on the north wall plus one outlet in the hallway. I suppose that side of the kitchen could be declared the dining room, but I replaced it with a GFCI anyway. I've got a freezer plugged into it, so its kitchen to me.
Just becasue it's kitchen does not mean it requires or needs GFI protection.
The kitchen, DR, pantry, nook, etc., are all considered the same area and follow the same rules. Only counter receptacles require GFI protection.
The fourth circuit (#2 breaker) had two GFCIs plus the switched disposal outlet under the sink. The disposal outlet was not GFCI nor was it on the load side of the existing GFCI.
Now this is an issue. Not the GFI. A disposal does NOT need GFI protection. Thing is the disposal is not allowed on with the counter receptacles. Not a huge deal though, mainly a convenience issue not a safety issue.
Old 04-26-2009, 07:44 PM   #18
Bigplanz's Avatar
Rewards Points: 996
These are interesting observations, and led me to take a tour of my own kitchen and it's receptacles. First, it was all wired pre-1990. When I moved in, there was no GFCI protection anywhere. I replaced the receptacle two feet from the sink, but left the one alone on the counter top four feet further down from the sink. NEC 2008 says GFCI is required:
210.8 (6) Kitchens — where the receptacles are installed to serve the countertop surfaces
So, for a 'new' kitchen, yes, GFCI protection is required. However, if an installation was code compliant at the time of installation, it is still code compliant. You (as the home owner) can certainly upgrade the level of protection, but you aren't required to.
Old 04-26-2009, 08:27 PM   #19
Rewards Points: 2,350
So the neutrals in that switch box are screwy. That's what it looked like to me but I couldn't tell for sure. I'd at least fix that.
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
Elec short causing A/C problems or A/C problems causing elec problems? Marlon Electrical 2 06-25-2008 02:04 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
