Wiring Problem - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 07-09-2012, 07:00 PM   #31
Tdsgraffiti's Avatar
Is there anyway I can just hook up the light and forget the rest? At this point I don't really care about losing a receptacle. :P
Tdsgraffiti is offline   Reply With Quote
Old 07-09-2012, 07:19 PM   #32
MarginallyQualified
Rewards Points: 2,464
Yes.
Remove the red wire from the receptacle.
Put a wirenut at each end.
Tie the ORIGINAL whites together and the ORIGINAL blacks together.
Done.
For the new wire to the ceiling light...
Tap into the whites and add the new white wire.
Tap into the blacks to add a short piece of black wire.
Attach this short piece and the NEW black to the switch.
Done.
Old 07-09-2012, 07:21 PM   #33
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
delete...
Old 07-09-2012, 08:30 PM   #34
Originally Posted by TarheelTerp
Yes.
Done.
Done.
The last part, did you mean "Attach this short piece "AS" the NEW black to the switch"?
Old 07-09-2012, 08:34 PM   #35
MarginallyQualified
Nope.
The short piece is the new hot that gets switched.
The new black wire gets switched and goes to the light.
Old 07-09-2012, 09:34 PM   #36
One more thing before I flip the switch. After the red wire is capped on both ends, for the receptacle end, is it just wired like a normal receptacle? Black on one side white on the other?
Old 07-09-2012, 09:35 PM   #37
MarginallyQualified
Yep.
Hope the others are wired right
Old 07-09-2012, 10:30 PM   #38
Now I have constant power to the receptacle. But no power to the switch.
Old 07-09-2012, 10:32 PM   #39
No power from the switch. The ceiling light is not coming on.
Old 07-10-2012, 06:55 AM   #40
Rewards Points: 2,516
Is there voltage at the wire pointed to in the photo?
hammerlane is offline   Reply With Quote
Old 07-10-2012, 06:59 AM   #41
E2 Electrician
This has to be the longest thread ever on installing a switch.
Old 07-10-2012, 07:00 AM   #42
And these background/wall colors are killing me.
Old 07-10-2012, 07:02 AM   #43
E2 Electrician
Originally Posted by hammerlane View Post
Ant these background/wall colors are killing me.
They are pretty loud.
To the OP, I would start over, you need to trace out the wires so you can properly make up the splice, without voltage readings and a little bit of electrical knowledge you may never get it right.
Old 07-10-2012, 07:04 AM   #44
I'm pretty sure there was power, I'll have to check again when I get home from work.
And yeah, definitely the longest thread for something that is normally so simple.
It's my little girls room, she wanted something represents bubble gum. :P sorry for the eye strain.
Old 07-10-2012, 07:06 AM   #45
E2 Electrician
Were just teasing on the wall color. but really, Im having a hard time not believing that the 3 wire in the switch box isn't the same wire that goes to the wall receptacle...
The Following User Says Thank You to stickboy1375 For This Useful Post:
jbfan (07-10-2012)
Electrical wiring exposed....problem or not?? pipsal Electrical 4 03-22-2010 12:49 PM
AC wiring Problem SLEDGEHAMMER84 HVAC 12 01-22-2010 01:13 AM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 08:48 PM
Home wiring problem CAD Electrical 8 10-17-2009 03:26 PM
Outdoor AC on whenever heat is on - wiring problem? SammyLi HVAC 3 10-12-2008 01:29 PM
