#1 |
Wiring problem
Have a switch that was taken apart, put back together and now it doesn't work. I did not see the setup before and now I'm confused as to how it goes back together... It is a switch that controls a single side of a wall socket. The other side of the socket has constant power.
Or if I could just turn it Into a single switch for a light in the center of the room? |
#2 |
Wiring problem
Also, this is what the receptacle looks like that the switch is powering.
#3 |
MarginallyQualified
Wiring problem
judging by how short the white wires are... I'd say they get wirenutted together.
The red wire is PROBABLY the switch leg. The two blacks are PROBABLY the always hot and the feed through. Five minutes with a good tester would tell the tale. |
#4 |
Wiring problem
The red and black on the left side are hot.
#5 |
E2 Electrician
Wiring problem |
#6 |
Wiring problem
What do you mean by that? This switch was working correctly at one point.
#7 |
E2 Electrician
Wiring problem |
#8 |
Wiring problem
No receptacles were changed.. It was originally removed because my girlfriend thought she could put any old switch in to replace the one that was there. She put it in and it didn't work, do she left it like that.
Now what I really want to do is put in a light in the center of the ceiling and have that switch control it.. |
#9 | |
E2 Electrician
Wiring problemQuote:
#10 |
Wiring problem
I can run a new wire no problem, but how would I wire this back together, make the receptacle functional, and have the switch only control the fixture in the ceiling?
#11 |
E2 Electrician
Wiring problem
at the switch location, wire all the whites together including your new cable, wire all the blacks and red together, EXCEPT the black from your new cable, that wire goes to the switch, then add a pigtail from the previous blacks and red splice to feed the switch.
#12 |
Wiring problem
Thanks so much for the info. I will try this out when I get home. I'll post the outcome.
#13 |
E2 Electrician
Wiring problem |
#14 |
Wiring problem
If I was to hook it up the first way, what's the worst that could happen?
#15 | |
MarginallyQualified
Wiring problem
Look at the first picture again... see the black wire on the left?
if has a stripped insulation section in the middle. That part goe on one screw of a standard switch an the red goes on the other screw of that standard switch. The other end of that black wire gets wirenutted to the the other black wire and the two whites get wirenutted together This puts the switch box the way it belongs. --- Quote:
you'll trip the breaker. That problem will be answered in your next thread. Last edited by TarheelTerp; 07-08-2012 at 07:04 PM. |
| Display Modes | |
| Electrical wiring exposed....problem or not?? | pipsal | Electrical | 4 | 03-22-2010 12:49 PM |
| AC wiring Problem | SLEDGEHAMMER84 | HVAC | 12 | 01-22-2010 01:13 AM |
| Problem with Lennox Pulse Furnace Wiring to Thermostat | scalvin | Electrical | 4 | 12-30-2009 08:48 PM |
| Home wiring problem | CAD | Electrical | 8 | 10-17-2009 03:26 PM |
| Outdoor AC on whenever heat is on - wiring problem? | SammyLi | HVAC | 3 | 10-12-2008 01:29 PM |
