Wiring Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 06-26-2012, 06:59 PM   #1
Rewards Points: 119
Wiring problem
I want to install a ceiling fan in the living room. It had a fan before we bought the house but the fan was gone. Now there is black, red, white and green wires coming down . Green is ground, white neutral. The black shows full voltage but the red half voltage based on a switch being on . What is the red stranded wire? The house is 1976.
debd is offline   Reply With Quote
Old 06-26-2012, 07:13 PM   #2
joed's Avatar
Rewards Points: 12,858
The red is probably controlled by the switch on the wall for the light. The unswitched black would have been used for the fan. Fans are often installed so that the fan can be controlled by the pull chains and the light by a switch on the wall.
Electrical wiring exposed....problem or not?? pipsal Electrical 4 03-22-2010 11:49 AM
AC wiring Problem SLEDGEHAMMER84 HVAC 12 01-22-2010 12:13 AM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
Home wiring problem CAD Electrical 8 10-17-2009 02:26 PM
Outdoor AC on whenever heat is on - wiring problem? SammyLi HVAC 3 10-12-2008 12:29 PM
