Wiring Problem: 120V To 12V Halogen Ceiling Lights With Transformer - Electrical - DIY Chatroom Home Improvement Forum
Old 06-25-2009, 10:22 AM   #1
wiring problem: 120V to 12V Halogen Ceiling Lights with transformer
Hi, I am trying to install a halogen pendant light in my kitchen, however, I have no idea how to connect the wires. Here is the installation manual for the fixture.
http://www.cdnlighting.com/sites/default/files/mti.pdf
The fixture comes with a transformer, it have 2 red wires, 1 white wire and 1 black wire.
The 12V lighting comes with 1 white wire and 1 black wire.
The normal power cable have 1 white wire, 1 black wire and ground.
How do I connect them?
The stupid installation manual never talk about the red wires in the transformer, do you guys have any suggestion? Actually, it is my first time to install a 12V halogen light.
Thanks!!!
Uncledan is offline   Reply With Quote
Old 06-25-2009, 11:36 AM   #2
DIY'r
ScottR's Avatar
Based upon your description, my guess would be that you connect either red wire to the black wire from the lamp, and the other red wire to the white wire of the lamp.
Then connect the black wire from the transformer to the black 120V power cable, and the white wire from the transformer to the white 120V wire.
But, the instructions make me see how you got confused.
Black Wire = 120V
White Wire = 12V
Factory Connected
Use Wire Nuts To Connect
WHITE Wires To Each End
Of Separated White Wires
It sounds like the wires to the lamp should have been factory connected..? I have a hard time believing that the white wire from the transformer is 12V, though who knows.
Can you post a pic of the markings on the transformer, or describe them if not?
ScottR is offline   Reply With Quote
Old 06-25-2009, 12:06 PM   #3
Remodeler
adpanko's Avatar
Rewards Points: 150
What wires are factory connected already? It looks like two of the wires from the transformer are already attached to the two wires that lead to the bulb, no?
adpanko is offline   Reply With Quote
Old 01-20-2010, 05:32 PM   #4
I think the two red wires are used on the transformer if you have a 3-way or 4-way lighing system
jabbers is offline   Reply With Quote
Recessed Lights problem Boycer88 Electrical 15 02-01-2009 07:23 PM
Ceiling Fan Wiring Help! wesr79 Electrical 10 02-28-2008 04:38 PM
wiring recessed lights question. SubSailor Electrical 2 02-25-2008 12:39 PM
Work lights in basement with drop ceiling fw2007 Electrical 2 10-20-2007 09:39 AM
Vaulted Ceiling Insulation Problem casey_wa Roofing/Siding 13 05-08-2006 09:55 AM
