Wiring Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 08-12-2011, 01:21 PM   #1
Wiring Problem
I'm in the midst of redoing my garage and the old fixture in the ceiling was something merely screwed into a bulb socket. I removed the old fixture today and it was a nightmare what I pulled out of the ceiling. I'm attaching a picture of what I pulled out.
What I'm trying to do is replace the light socket with a regular outlet so I can install two hanging shop lights.
This circuit is always on, not controlled by a switch that I'm aware of (because there aren't any in the garage). My parents moved into the house in 1977 so it was built some time in the 60's. That's all the info I have.
Any insight would be fantastic as to what I'm supposed to do.
mainegoer72 is offline   Reply With Quote
Old 08-12-2011, 01:34 PM   #2
I just went into the garage to close my garage door with the opener and it's not working. So not only do I have that wiring mess hanging from my ceiling, my garage door opener on the other side of the garage doesn't work either.
Just thought I'd add that to the mix!
Old 08-12-2011, 02:41 PM   #3
Licensed electrician
Rewards Points: 1,634
There should have only been two wires connected to the old socket. Any other splices should have been left alone.
Old 08-12-2011, 07:13 PM   #4
But that's the thing, there wasn't! That's why when I went to put in the outlet I made the right connections and it tripped the breaker. If it was working before it should be working again. I isolated all the hots because I didn't have a wire nut big enough to hold 3 wires.
Sent from my iPad using DIY Forum
Old 08-12-2011, 07:17 PM   #5
Experienced
Jackofall1's Avatar
Do you have a meter?
I will bet there is one hot and 2 not
Mark
Old 08-12-2011, 07:50 PM   #6
Yeah I can run the multimeter to see what's hot. I just didn't want to short anything out again.
Old 08-12-2011, 07:59 PM   #7
Johnboy555's Avatar
H!..
The black wires were probably connected, providing a "run through" to the EDO (electric door opener) outlets. Just connect the 3 black wires with 1 wire nut.
The red wire would be your "switch leg" providing control to your light.
You can get a "duplex" (outlet) cover for that box at HD. You would connect the single red wire to the brass (hot) side of the outlet, and the wire that's connected to the whites to the silver (neutral) side of the outlet. If there is not enough room for the wires and outlet in the box, they have a 4" box "extension" ring that you can screw on the existing box to give you the room needed. It looks just like the existing box, without a "back" .♦
Johnboy555 is offline   Reply With Quote
Electrical wiring exposed....problem or not?? pipsal Electrical 4 03-22-2010 11:49 AM
AC wiring Problem SLEDGEHAMMER84 HVAC 12 01-22-2010 12:13 AM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
Home wiring problem CAD Electrical 8 10-17-2009 02:26 PM
Outdoor AC on whenever heat is on - wiring problem? SammyLi HVAC 3 10-12-2008 12:29 PM
