Old 10-08-2012, 02:02 PM   #1
Wiring - power to light then switch
Got cable running from the panel. Nothing on circuit presently.
Like to use the circuit to
1. install a light operated by a switch
2. replace the 220 AC receptacle (no longer needed) with 110 receptacle
3. add another receptacle before or after the switch.
I'd like to use the three existing cable runs, which means the power will run from the panel to a junction, then the light / switch / replacement receptacle (see pic).
I'll add the new receptacle near the switch later.
Cable from new ceiling light not shown... Black, White, and Ground.
Question is, does power going into the light first affect the wiring to the switch?
dcj710 is offline   Reply With Quote
Old 10-08-2012, 04:19 PM   #2
Yes.
You will need to wirenut the incoming black to the black in the cable going to the switch. At the switch, connect the black to one terminal and the white to the other. Mark the white with a black piece of tape to indicate it is NOT a neutral. The white/black then carries the switched hot line back to the light fixture, where you again mark it with black, and connect it to the black wire from the fixture.
Dave632 is offline   Reply With Quote
The Following User Says Thank You to Dave632 For This Useful Post:
dcj710 (10-08-2012)
Old 10-08-2012, 04:26 PM   #3
he has xx-3 going to the switch, make up all blacks/whites/grounds together with the like wires, use the red from the switch to feed the light.
Techy is offline   Reply With Quote
The Following User Says Thank You to Techy For This Useful Post:
dcj710 (10-08-2012)
Old 10-08-2012, 04:45 PM   #4
Sorry, missed that.
dcj710 (10-08-2012)
Old 10-08-2012, 07:10 PM   #5
Not using the red at either end (xx-3 is existing cable; using it instead of running new cable). So Dave632's first diag should work. But it doesn't. I get light all the time; switch doesn't affect it.
Old 10-08-2012, 09:02 PM   #6
I've looked at Dave's diag (not using red wire to switch - per Techy's xx-3 comment) and ck'd the connections a few times. New switch, but replaced that anyway. I'm missing something.
The light goes on with the breaker. But it does NOT shut off at the switch. ???
Old 10-08-2012, 09:26 PM   #7
It would be better to use the red conductor.
At the light, black to black ... white to white (tie whites to fixture), red to switch and light, cap the white at switch.
Gac66610 is offline   Reply With Quote
The Following 2 Users Say Thank You to Gac66610 For This Useful Post:
dcj710 (10-08-2012), k_buz (10-08-2012)
Old 10-08-2012, 09:33 PM   #8
DIY Enthusiast
sublime2's Avatar
Connect the blk from panel to black "old ac" with white to switch. Connect blk switch wire at jb to fixture,connect white fixture wire to all remaining whites in jb and wire not. Connect blk and white at switch to screws and mark white with black tape.
sublime2 is offline   Reply With Quote
The Following User Says Thank You to sublime2 For This Useful Post:
dcj710 (10-08-2012)
Old 10-08-2012, 10:12 PM   #9
Licensed Electrician
k_buz's Avatar
Is there any other cables at the switch? or just the 3-wire?
It appears you didn't get the correct advice here if you are adding a receptacle coming off the switch.
Connect the all the blacks together
Connect all the whites together
Red and black to the switch, cap the white for a future neutral
Black of the fixture to the red in the ceiling
White of the fixture to the 3 whites in the ceiling
Location...Location...Location
The Following User Says Thank You to k_buz For This Useful Post:
dcj710 (10-08-2012)
Old 10-08-2012, 11:14 PM   #10
DIY Enthusiast
sublime2's Avatar
Since you stated your not using the red ( only there because that's the wire you have available)
If there was no red wire the above would also work.
dcj710 (10-08-2012)
Old 10-08-2012, 11:36 PM   #11
No other cables at the switch.
And yes, I'd like to add a receptacle later. Receptacle could be located just before or just after the switch...either would be OK.
Old 10-09-2012, 12:22 AM   #12
Just finished trying the above...still not right. Light's on with the breaker; off with the breaker.
Switch doesn't turn the light off.
Replaced the switch again (3rd one).
I'm doing something wrong, but damned if I can see what it is. Maybe it'll look different in the morning.
Old 10-09-2012, 12:59 AM   #13
Try this. Grounds not shown.
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
dcj710 (10-09-2012)
Old 10-09-2012, 06:53 AM   #14
Oso954's diagram will work. Below is simialr only that the outlet(receptacle) is after the switch.
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
dcj710 (10-09-2012)
Old 10-18-2012, 08:41 PM   #15
Changed the switch (second time). Replacement switch was bad.
3 and 4 way switches - power to first light mmrossen Electrical 3 12-04-2011 10:07 PM
2 Wires in to light, 3 Wires out, no juice on the switch prytoo Electrical 4 11-28-2011 06:24 PM
light switch wiring question. dannat Electrical 4 05-05-2011 10:11 AM
No power to light fixtures or switch in garage mrsirmrman Electrical 5 09-29-2010 04:36 PM
no power going to the light switch baseballfan Electrical 18 09-08-2008 06:35 PM
