Wiring Power To Detached Garage, More Questions - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-23-2011, 02:24 PM   #16
I ask the impossible!
Rewards Points: 660
Can SEU be used underground in conduit?
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Old 04-24-2011, 12:02 AM   #17
Rewards Points: 660
K I think I found the answer to my own question searching Yahoo I came across where a similar question came up on Mike Holt's forum and the code reference points to a code line that's new in 2008 where it indicates SE type cable can't be used underground with or without raceway. So the answer is no I can't use SEU in conduit underground.
Apparently it isn't explicitly forbidden prior to 2008 NEC, but some inspectors interpret earlier versions of NEC as disallowing SE in conduit underground because SE is not allowed in wet locations and underground is a wet location.
I'll plan to procede on the assumption SEU can't be used whether I'd meet 2005 code or not, I believe my locality is supposed to be on 2008 as of this mnth, I also believe my inspector tends to err on the side of stricter interpretation.
So, I already bought 50' of SEU. Anyone in SE Michigan want to buy it at a discount?
Old 04-24-2011, 12:48 AM   #18
Scared Electrician
Saturday Cowboy's Avatar
It was illegal under 2005 but not very clear, in 2008 they put all of the info in one spot, so a lot of people think its new.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Questions regarding wiring 220 to attached garage... John Green Electrical 0 01-20-2011 09:23 AM
Wiring Detached Garage for 220v welder 8N1949 Electrical 2 03-11-2010 08:47 AM
Wiring a Shed and Garage abedj Electrical 1 05-08-2009 11:09 AM
Critique my wiring plan for my garage tigereye Electrical 10 03-24-2009 09:55 PM
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 12:17 PM
