Wiring Pot Lights For Basement - Electrical - DIY Chatroom Home Improvement Forum
Old 06-29-2011, 10:54 PM   #1
Rewards Points: 160
Wiring Pot lights for Basement
Just looking to wire in the wires before we put up the drop ceiling.
I think I can run one wire around the entire area and leave enough slack so that when I put in the lights I can just connect the lights in series one after the other.
Is there a standard spacing or a general rule of thumb on how many lights needed per area?
hellothere123 is offline   Reply With Quote
Old 06-30-2011, 01:18 AM   #2
rbj
There is commercial specs, but resi permits 3w/sq ft for general purpose. When installing luminaires, it is best to determine how the task or mood lighting areas are going to be located. Determining illuminated areas can be easier to see by visiting the showroom and have a sales person demonstrate the fixture housing reflectivity patterns you want.
rbj is offline   Reply With Quote
Old 06-30-2011, 06:45 AM   #3
Rewards Points: 1,542
Three watts per square foot is used to determine hoa many amperes your panel and incoming electrical service needs to be (load calculation). Not how much light you need in a room.
Can lights are usually spaced uniformly and intended to light the area uniformly. Additional lights, either on the ceiling or wall, are usually used to accent some areas. As a rough rule, the fixtures nearest the walls are spaced away from the wall half the distance between two fixtures.
Allow two feet of slack in the cable for each fixture.
Old 06-30-2011, 11:37 AM   #4
rbj
You are correct. What's the matter with me. I am so used to using [220.42] for general lighting distribution from load calcs that I neglected to mention lamp reflected performance based on footcandle radiated luminosity. Frankly residential does not have a true reference for point or zonal space pattern compared to commercial constraints. Cavity charts that deliniate spacing and uniform surface reflectivity using the Coefficient of Utilization boils down to spacing and distance of lumens to reach walls and the workplane surfaces from the light source.
Best way to route wiring for can lights? sheslostcontrol Electrical 3 01-10-2011 04:19 PM
Wiring question - two lights with one switch... Cleon26 Electrical 3 12-28-2010 09:09 AM
Wiring Basement Recessed Lights RyanNirg Electrical 1 10-14-2010 05:40 PM
Wiring lights with power coming into first light rovers1973 Electrical 2 08-23-2010 06:52 AM
Wiring Outlets Then Switch Then Lights heydj Electrical 9 05-07-2009 08:09 PM
