Wiring Pot Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 02-22-2011, 06:08 PM   #1
wiring pot lights
how can I wire 3 pot lights on a circuit when the power source is coming from a recepatacle. the pots come before the switch
richie89m is offline   Reply With Quote
Old 02-22-2011, 06:18 PM   #2
Coatings Nerd
I don't think you can
www.northcromwellpaint.com
Benjamin Moore, Sikkens, TWP, PPG, Airless sales and service
NCpaint1 is offline   Reply With Quote
Old 02-22-2011, 06:30 PM   #3
Rewards Points: 1,548
A common problem with pot lights is that the connection boxes for the wires are quite small. Perhaps too small to support 3 wire cable going between them.
So you need to run the power using a 2 wire cable to the switch first. If the best route would go through the lights, the cable to the switch can run unbroken past the outside of the lights.
Old 02-22-2011, 06:32 PM   #4
Licensed electrician
Rewards Points: 1,890
You would run a 2 wire + ground cable from the receptacle to the light. From the light you would run a 3 wire + ground between the lights and then to the switch. The blacks will splice thru. The reds will splice to the fixture blacks. All white together. All grounds together. The black and white will splice to the same colors at the receptacle. Also the grounds.
Best way to route wiring for can lights? sheslostcontrol Electrical 3 01-10-2011 04:19 PM
Wiring question - two lights with one switch... Cleon26 Electrical 3 12-28-2010 09:09 AM
Wiring Basement Recessed Lights RyanNirg Electrical 1 10-14-2010 05:40 PM
Wiring lights with power coming into first light rovers1973 Electrical 2 08-23-2010 06:52 AM
Wiring Outlets Then Switch Then Lights heydj Electrical 9 05-07-2009 08:09 PM
