#1 |
Wiring a pool - 10/3 UF in conduit
I'm thinking of running a line to my pool. From what I understand, the code states that the ground must be insulated, thus the only option is to run conduit with separate wires (THWN water resistant wires). I was wondering if I could run UF wire (10/3 with ground) and just not use the bare ground wire. I would also install this in gray PVC conduit for greater protection...
#2 |
Licensed electrician
#10-3 UF is wide and flat. By the time you wrestled it into conduit you will wish you had used individual conductors. You also cannot repurpose the red to be a grounding conductor. The insulation color is wrong and it cannot be taped green under the rules.
Answers based on the National Electrical Code. Local amendments may apply. Check with your local building officials. |
#3 |
I knew there had to be a reason it was not a common thing to do....thanks for the fast response...I know what needs to be done now...
#4 |
Inspector/Instructor
Wiring a pool - 10/3 UF in conduit |
#5 |
Xtreme DIY'r
#6 | |
Wiring a pool - 10/3 UF in conduitQuote:
| Display Modes | |
| Intex Pool goes underground | arbizval | Building & Construction | 5 | 06-05-2011 09:34 AM |
| Swimming Pool subpanel | tedpoppke | Electrical | 3 | 08-24-2010 09:59 AM |
| Working with PVC Conduit | jasonnewyork | Electrical | 13 | 07-23-2010 01:38 PM |
| Code requirements for low voltage wiring in conduit with 120V | flyboy | Electrical | 9 | 12-24-2009 07:48 PM |
| Pool Care Guide | scottiedog | Landscaping & Lawn Care | 16 | 06-07-2008 09:41 PM |
