I'm thinking of running a line to my pool. From what I understand, the code states that the ground must be insulated, thus the only option is to run conduit with separate wires (THWN water resistant wires). I was wondering if I could run UF wire (10/3 with ground) and just not use the bare ground wire. I would also install this in gray PVC conduit for greater protection...
#10-3 UF is wide and flat. By the time you wrestled it into conduit you will wish you had used individual conductors. You also cannot repurpose the red to be a grounding conductor. The insulation color is wrong and it cannot be taped green under the rules.
No he was going to remark one of the insulated wires as the ground
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
