Old 06-08-2012, 06:55 PM   #1
Wiring Plan
I am finishing my basement and this is the wiring plan that I am going to present to Ontario electrical inspector. I would appreciate any suggestion regarding the wiring.
To be considered:
1- According to local electrical code I can do the job.
2- According to Local building code , having a kitchen in the basement is not permitted.
3- All the lights except Bath wall-mount light, are recessed IC.
navid is offline   Reply With Quote
Old 06-08-2012, 07:33 PM   #2
MarginallyQualified
Wiring Plan
That's purty.
Does it work?
TarheelTerp is online now   Reply With Quote
Old 06-08-2012, 08:30 PM   #3
Wiring Plan
That's a lot of stuff on 3 circuits.
Are you allowed to put the bathroom and other rooms on the same circuit in Ontario?
I think there is a limit to how many outlets (meaning lights and receptacles) you can have on a circuit in Canada.
AandPDan is offline   Reply With Quote
The Following User Says Thank You to AandPDan For This Useful Post:
navid (06-08-2012)
Old 06-08-2012, 09:07 PM   #4
Wiring Plan
Thanks for your reply.
Rule 26-710 [C] : Bathroom Plug Outlet might be supplied with any nearby lighting circuit which has 11 or fewer outlet.
The maximum outlet number (lights and receptacles) is limited to 12, but according to Rule 8-304 : Where the load is known the Code permits more than 12 outlets on a 15 amp circuit provided the total load current does not exceed 12 amps.
In this case, the marked maximum lamp size on the fixture is known and no other loads is connected to this circuit.
Old 06-08-2012, 09:34 PM   #5
Wiring Plan
No offense but remember that when you're watching TV and someone plugs in a hair dryer and trips the breaker.
The maximum outlet number (lights and receptacles) is limited to 12, but according to Rule 8-304 : Where the load is known the Code permits more than 12 outlets on a 15 amp circuit provided the total load current does not exceed 12 amps.I n this case, the marked maximum lamp size on the fixture is known and no other loads is connected to this circuit.
I'd still suggest you break it up some more. It's easy to add a few circuits now, while you can, instead of after the walls are done. As is, if that "purple" circuit breaker trips you have no lights in the "entertainment area" or "room 1" or either set of stairs.
Plan for the future, not today's loads. You may not have one now but how much power does a big Plasma TV take or a surround sound system need? I'd dedicate a circuit just for them and keep the lighting off of it. Do you have enough receptacles, spaced for Code? I see no receptacles near either set of stairs.
Code is the bare minimum. It does not mean that you can't do differently.
navid (06-08-2012)
Old 06-08-2012, 11:14 PM   #6
Wiring Plan
Good suggestions I will add more receptacles and breakers.
there are 5 free spots for breakers.
Old 06-12-2012, 01:57 PM   #7
Wiring Plan
Are you planning any electric in the utility room?
I think that the bathroom lighting should have a wall switch on the inside of the bathroom door, not outside. Other readers should/would know.
Ray103 is offline   Reply With Quote
OK, think I have this right - wiring plan for finished basement orcusomega Electrical 10 12-08-2010 09:56 AM
Correct wiring diagram for 1 story house jdm001 Electrical 63 06-24-2010 05:35 PM
Tiling stub surround -- my detailed plan 99miles Remodeling 1 08-17-2009 05:55 PM
Kitchen Wiring Plan - ok? Knucklez Electrical 19 07-14-2008 08:22 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 12:52 PM
