Wiring Of Pergola - Electrical - DIY Chatroom Home Improvement Forum
Old 05-29-2011, 12:29 PM   #1
wiring of pergola
I am building a new pergola, and want to wire it for lighting with the least visual impact - my wife doesn't feel that bare conduit is particularly attractive. The pergola generally consists of a series of parallel 2x10 joists atop 4 posts - all open to the heavens above. I can get the wiring up the inside of one of the posts, but from there, will have to run it along the joists. Do I need metal or plastic conduit or can I staple or clamp UF cable to the side of a joist? (I might camouflage it ith a narrow strip of wood). The flexibility of cable vs conduit is also appealing.
jmhultin is offline   Reply With Quote
Old 05-29-2011, 02:36 PM   #2
Scared Electrician
Saturday Cowboy's Avatar
UF cable does not have to be run in conduit! However take care that the sun does not degrade it. It must be listed for in the sun, but even then I've seen some pretty rotten stuff because of the sun. I recommend covering or painting it.
Now if this was my project I would put it in conduit. I think it looks neater and painted to match the wood it would blend in. Remember all splices must be made in WP boxes w/ WP lights.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 05-29-2011, 02:43 PM   #3
Rewards Points: 1,016
I would recommend to use conduit - if you can run it on top of the pergola much as possible the visual impact will be reduced.
Old 05-29-2011, 04:07 PM   #4
Thanks I appreciate you thoughts, but let me press the question a bit further - does cable, not in conduit, have to be a certain distance above the ground? For example, I believe a suspended overhead cable needs to be a certain minimum height, but how about a cable attached to a support member?
(and you're right, I'll probably run it in the conduit anyway).
Old 05-29-2011, 07:39 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
I have taken a piece of wood the same material as the pergola and cut a dado that will cover the UF cable.Secure with trim head screws outside the area of the dado.
Coastal South Carolina
Old 05-30-2011, 01:15 AM   #6
Scared Electrician
that could be considered a violation. as you need a 1 1/4" of material or nail plates to protect wiring
Old 05-30-2011, 02:48 PM   #7
thanks for your ideas - I'll probably go with the conduit.
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 08:53 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 07:45 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 03:40 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 11:33 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
