Wiring Past A Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 06-23-2011, 09:31 PM   #1
Wiring past a switch
I recently re wired my basement with multiple switches on one circuit. In order for everything beyond the switch to not be controlled by the switch i put in a junction box and ran from there to the switches. I have two questions... Is there anything wrong with what I've done and 2 what is the correct way to wire a circuit with a switch in the middle of it and not having it control everything beyond that switch. I'm a carpenter trying to play sparky and unfortunately shop class was a few years ago.
boozehound is offline   Reply With Quote
Old 06-23-2011, 09:46 PM   #2
joed's Avatar
Rewards Points: 11,632
If power comes into the switch then simply connect you circuit past the switch to the power in cable and not to the switch.
If this is a switch loop setup then you need to run a three wire cable instead of two wire cable so that you can bring the neutral into the switch box.
There is no problem using a junction box as long it remains accessible. You can't bury under drywall.
Wiring an Intermatic Wall Timer in a three way switch aitutaki98 Electrical 6 07-23-2011 12:43 PM
Fitting dimmer switch to old electrical wiring hugomax69 Electrical 0 01-29-2010 08:40 PM
Switch on K&T wiring - OK to pigtail? fdmillion Electrical 4 01-27-2010 10:15 AM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
