Old 11-07-2009, 03:29 AM   #1
Default Wiring a Panel
Hello All,
I am under full NEC 2008 regs here, and am trying to figure out exactly how to wire my panel in my new detached garage. I am going to be pulling directly off the meter socket. Specifically, I am confused on the grounds and neutrals. Do I run the main, rod, and rebar grounds to the grounding bar? How are the neutrals tied in then, thru the panel itself?
DigitalFusion is offline   Reply With Quote
Old 11-07-2009, 06:45 AM   #2
At a main panel (panel with the main disconnecting means) the grounds and neutrals are bonded together. The neutral bus also is bonded to the panel box.
Old 11-07-2009, 12:10 PM   #3
zpm
yeah, right
Explain exactly what you mean by that.
Detached garages are normally subpanels fed from the house panel.
But if you have a separate service at the garage, it could be a main panel.
Honey, does this tool belt make me look FAT?
zpm is offline   Reply With Quote
Old 11-07-2009, 12:17 PM   #4
J. V.'s Avatar
Install a grounding terminal terminal strip and land both grounding and bonding wires to it. Connect the neutral to the neutral lug and do not install the green bonding screw that came with the panel. If the green screw is installed remove it. This screw bonds the neutral lug and terminals to the enclosure. You do not want to bond the neutral at the sub panel. The grounding strip is bonded to the enclosure. It is important that they stay separated. Put all the bare grounds (EGC) on the grounding terminal strip. Put all the white neutrals on the neutral terminal strip.
By design the neutral terminal strip is insulated from the enclosure. The green bonding screw that came with the panel is for bonding this terminal strip. In this instance you will not use it.
Ps.....You cannot run a feeder directly from the meter for a sub panel. It must be fed from a circuit breaker or fuses. The best place to feed the sub panel is from the existing main panel in the house.
What size wire did you pull? That looks like a 100 amp panel. If it is you need #3 Cu for the two hots and a #8 for the ground (EGC).
Old 11-07-2009, 12:23 PM   #5
This isnt a sub-panel. It is not connected to the house panel at all, in no way, shape, or form. The power will be coming directly from the meter socket. One lug in the meter socket goes inside the house, the other lug feeds my garage panel. The Inspector knows about this, and it is legal.
http://www.milbankmfg.com/products/c...pConnector.pdf
I have been searching around all morning. I am even more confused now! Two electricians, and the inspector said this would be code-legal, but everything I seem to find says that I should be doing a sub-panel, or that this is not legal?
The main panel in the house only has 2 slots left in it, and I am trying to avoid putting more holes in the side of the house, and filling up the panel in the house. I was told that using the item linked above, would allow me to skip going into the house, and give me true 100amp service in the garage, instead of sharing the 150amp service in the house. Im so lost right now.
Old 11-07-2009, 02:01 PM   #6
Ok. I think I understand it now. What was throwing me off is that ground in the main feed. When I originally (nearly a year ago) pulled those feeds, I planned on tapping into the main panel in the house. Then I learned about the load-tap connectors.
I dont need the grounding bar kit on the left side of the panel. I connect everything like a main panel in a house. I wonder what the inspector wants me to do with the rouge ground wire?
Old 11-07-2009, 02:23 PM   #7
Extreme DIY Homeowner
Scuba_Dave's Avatar
Dual lug meter feeds are OK to use as your Inspector has indicated
He's the one that does the Inspection
I'm not sure what you mean by Rouge ground wire?
Copper wire goes to the ground lug on the panel
Any other ground should also go to lug/bus grounding location
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/f49/house-renovation-ongoing-37438/
Old 11-07-2009, 07:14 PM   #8
i meant the ground wire coming in with the main feeds. It was no longer needed with the meter feed. I hope I did everything right!
The pic was taken before I marked the 240v white wire as hot with black tape.
Old 11-07-2009, 07:37 PM   #9
zpm
yeah, right
Probably get rid of it. Connecting it would create a parallel neutral path.
Old 11-07-2009, 07:58 PM   #10
thats what I did. I pulled it completely out of the conduit.
Old 11-08-2009, 01:52 PM   #11
J. V.'s Avatar
Deleted.
More On This Topic
Hi! I'm Jeff Wong with Expert Village and today we are going to learn how to change a flat tire. The first step in removing a flat tire is to remove either the hubcap or the center cap that may block the lug nuts. To do so, simply pry the edges of the... Read More »
Hi, I'm Aaron Gregory on behalf of Expert Village. We're going to talk about what happens when your car battery dies, how to select a new battery, and how to see what the problem is. Okay, here is the car battery in this particular car. Some cars will... Read More »
Hi! My name is Adolph Ramirez from Tampa, Florida on behalf of Expert Village, this is how to install a ceiling fan. Make sure you disconnect all of your power; shut it off at the service panel. Don't rely on any kind of switches or anything like that... Read More »
Everyone should know how to change a tire on his or her vehicle. These skills should be practiced often to reach optimum comfort in changing a tire. The steps that follow are based on changing a tire on an Expedition. Read More »
Changing tire is a useful task for everyone to learn. This skill should be practiced often to reach optimum comfort in changing a tire. The steps that follow are based on changing a tire on a Ford Expedition. Read More »
wiring from existing panel to new garage al99m Electrical 8 07-29-2009 10:42 PM
wiring 220 into sub panel danma Electrical 4 07-28-2009 12:28 PM
Exterior Wiring Questions elliowb Electrical 10 01-07-2009 10:01 AM
Wiring a sub panel? motorcity11 Electrical 8 10-23-2008 04:02 PM
Wiring from panel Rick N. Electrical 1 02-17-2004 10:55 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
