Wiring From Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 02-13-2004, 07:39 AM   #1
Guest
Guest
Posts: n/a
Question
Wiring from panel
I am finishing my basement and will be adding 8 circuits. The circuits are planned, and the boxes have been hung.
My question is this:
In order to minimize the time the power is off, and in my opinion, to make it easier on myself, I would like to wire the circuits to the panel first and make runs to junction boxes where I will cap the wires until I am ready to continue.
This makes sense to me in that:
* I can run a full length of conduit (yep, it's code) to the panel and pull the wires while turning off the main once.
*I can test the circuits immediately before adding fixtures.
*Once I have wired a complete circuit, I can test it by simply flipping on the corresponding breaker.
While this seems like the way I would like to proceed, are there any problems with my logic, or any pitfalls that I am overlooking?
Thank You
Old 02-17-2004, 09:55 PM   #2
Guest
Guest
Posts: n/a
Sounds good except you'll be working in the dark.
Old 07-10-2013, 10:55 AM   #3
When I added two circuits in my basement, I followed a similar plan, but just ran conduit to the first receptacle.
I had lights from the existing circuit.
brgmgb is offline   Reply With Quote
Old 07-10-2013, 11:32 AM   #4
MarginallyQualified
Rewards Points: 2,464
Originally Posted by Rick N. View Post
In order to minimize the time the power is off... I would like to wire the circuits to the panel first and make runs to junction boxes where I will cap the wires until I am ready to continue.
Nope. Do everything else first.
set boxes, pull wire to first box, extend circuit, rough in the several device boxes and fixtures, and so forth...
THEN (and all at once) "land" your circuits in the panel. Test them.
Then turn them all off until after the devices and fixtures are installed.
Old 07-10-2013, 12:11 PM   #5
Rewards Points: 82
This is correct. Do everything else first.
Your very last job with be to "make up" the panel. That means make the connection s to the panel breakers and terminal strips.
Old 07-10-2013, 12:21 PM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 254
I hope the job is finished since it was started in 2004
The Following 3 Users Say Thank You to jbfan For This Useful Post:
HouseHelper (07-10-2013), Speedy Petey (07-10-2013), TarheelTerp (07-10-2013)
Old 07-10-2013, 05:25 PM   #7
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I was going to make a comment about AFCI's but I guess that really doesn't need to be said....
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
12v diff between ground and neutral at panel am9518 Electrical 7 02-25-2008 07:28 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 06:54 AM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 11:05 PM
