Wiring An Oven In 2.5? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-26-2012, 02:19 PM   #1
Question
Wiring an oven in 2.5?
Is there anything that actually stops me from wiring a 2.8kW oven in 2.5mm twin and earth? Done the cable sizing calculation and voltage drop and it's all legit, am I missing something though? I know a few people have said it better to wire it in 4mm/6mm incase a differemt cooker etc is ever put in, but is it dangerous for it to be wired in 2.5 for example could the cable overheat?
peterdevlin1 is offline   Reply With Quote
Old 04-26-2012, 02:20 PM   #2
Rewards Points: 1,668
Peter,
Your location? Sounds like not in the US?
bob22 is offline   Reply With Quote
Old 04-26-2012, 02:21 PM   #3
UK scotland
Old 04-26-2012, 02:29 PM   #4
Cruising into the sunset
JulieMor's Avatar
Rewards Points: 518
You need to find out conduit fill related to conductors. In the US, there are tables that specifically state how many conductors with a particular insulation can be installed in each size conduit. See if you can find the UK version of that.
JulieMor is offline   Reply With Quote
Old 04-26-2012, 02:31 PM   #5
Im not using conduit though? It's installed under a floow
Old 04-26-2012, 02:39 PM   #6
JulieMor's Avatar
Rewards Points: 518
So it's just a matter of planning for the future? If so, I'd say it's a cost vs. will you ever need a larger amperage circuit. If you've done the load calcs and you're sure you're good on the wire size and insulation, then all you need to decide is if you want to install larger wire in case you ever upgrade your oven.
When I first started my apprenticeship in 1974, we were installing 60A circuits for electrical ovens. I just replaced my gas oven with electric and only needed a 30A circuit. So in the future, your next oven could be even more efficient and you could find even a larger oven wouldn't require an electrical upgrade.
Sounds like it's a personal choice.
Tags
2.5 , cooker , oven , wire
wiring a built-in electric conection oven leemar Electrical 1 09-27-2010 10:05 AM
Cooktop and Stand Alone Oven Wiring Replacing Existing Single Range/Stove Combination ffauth Electrical 3 08-23-2010 09:03 PM
Wiring Cooktop and Under Counter Oven Preach_2 Electrical 18 03-19-2009 04:30 PM
oven wiring stan 41943 Electrical 8 03-24-2008 08:26 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
