Wiring Outside Receptacle Water Proof Box. - Electrical - DIY Chatroom Home Improvement Forum
Old 02-27-2009, 03:49 AM   #1
Wiring outside receptacle water proof box.
I am installing a stand alone outside receptical. The directions on the box say to wire the ground wire to the box. If I wire it to the box, I can't wire it to the receptical. Do I run a small piece of wire from the receptical ground screw to the box ground screw, or since the box is metal, is the ground to the box enough?
Thank you
erlindbl is offline   Reply With Quote
Old 02-27-2009, 05:44 AM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
If it's a surface mount box , you can remove at least one, if not both, screw retaining insulating washers and this will ground the receptacle.
Make sure you screw the receptacle up tight against the box.
wirenut1110 is offline   Reply With Quote
Old 02-27-2009, 10:57 AM   #3
Rewards Points: 58
Thank you
Sure you can. Connect a piece of wire to the ground terminal in the box. Then connect this wire to the circuit ground and the receptacle ground. Just put all three grounding wires under one wire or wing nut.
The box can be used as a ground, provided it is connected to metal conduit and has an unbroken metal path all the way back to the panel. I would still pull the ground anyway. IMO.
Old 02-27-2009, 02:35 PM   #4
Sounds good to me.... Thanks for the information....
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
Wiring tankless water heater TheBossQ Electrical 4 07-11-2008 01:05 PM
receptacle wiring, please help reds_21 Electrical 11 10-21-2007 08:24 PM
