Wiring Outside Lantern Lights? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-13-2007, 09:02 AM   #1
Rewards Points: 152
Wiring outside lantern lights?
Thanks guys.
In new construction when running a wire to a light that will be outside (like 2 lantern style lights on both sides outside of a sliding glass door); should a work box be used?
Siding will be on the exterior.
How do you normally do this?
sandyman720 is offline   Reply With Quote
Old 09-13-2007, 04:18 PM   #2
Electrician
You have to use a box, I usually use some type of siding block so the fixture sits flat against something.
chris75 is offline   Reply With Quote
Old 09-26-2007, 07:30 AM   #3
Rewards Points: 152
I just called my supply house and they said that the Siding block that I will be getting does not have an integrated electrical box. What type of box do you install for this type of application?
Thanks!
Old 09-26-2007, 01:08 PM   #4
" Euro " electrician
frenchelectrican's Avatar
Here try this product it work wonders with this one click on this link http://www.aifittings.com/whnew24.htm
this will give you a genral idea how to do this and i am sure many box store should stock this kind of item if not can stop by the electrical supply centre they useally have one on hand
Merci , Marc
Old 09-26-2007, 01:20 PM   #5
Rewards Points: 152
I have Certainteed siding Cyprus color. I was going to get a Cyprus color mounting block. So I need a box behind i
Wiring lights on vaulted ceilings Unregistered Electrical 4 01-31-2008 09:39 PM
Need help wiring 2 motion lights off one swithc poontz13 Electrical 2 08-10-2007 06:20 PM
recessed lighting wiring to 3way switch DIY4EVER Electrical 1 07-12-2007 01:35 PM
Permenant wiring of undercabinet lights Steven Electrical 1 11-16-2006 10:53 PM
Wiring for external lights and outlets MikeinBurien Electrical 4 12-05-2005 12:16 AM
