-   -   Wiring outside lantern lights? (http://www.diychatroom.com/f18/wiring-outside-lantern-lights-11503/)
sandyman720 09-13-2007 10:02 AM
Thanks guys.
In new construction when running a wire to a light that will be outside (like 2 lantern style lights on both sides outside of a sliding glass door); should a work box be used?
Siding will be on the exterior.
How do you normally do this?
chris75 09-13-2007 05:18 PM
You have to use a box, I usually use some type of siding block so the fixture sits flat against something.
sandyman720 09-26-2007 08:30 AM
I just called my supply house and they said that the Siding block that I will be getting does not have an integrated electrical box. What type of box do you install for this type of application?
Thanks!
frenchelectrican 09-26-2007 02:08 PM
Here try this product it work wonders with this one click on this link http://www.aifittings.com/whnew24.htm
this will give you a genral idea how to do this and i am sure many box store should stock this kind of item if not can stop by the electrical supply centre they useally have one on hand
Merci , Marc
sandyman720 09-26-2007 02:20 PM
I have Certainteed siding Cyprus color. I was going to get a Cyprus color mounting block. So I need a box behind i
