Wiring An Outlet Through A Cabinet - Electrical - DIY Chatroom Home Improvement Forum
Old 12-05-2012, 11:02 AM   #1
Rewards Points: 89
Wiring an outlet through a cabinet
Is there a particular way to go about doing this?
It's not going to be for an island but the vanity in the bathroom. The attached picture is how I would want it to look.
REXAMUS is offline   Reply With Quote
Old 12-05-2012, 11:07 AM   #2
Rewards Points: 2,516
Your use of the words "this" and "it" make it difficult to interpret what the this and it is that you are referring to.
hammerlane is offline   Reply With Quote
Old 12-05-2012, 11:30 AM   #3
Rewards Points: 89
This and it meaning an outlet installed in the side of a cabinet.
I wasn't sure if there was a particular box made for this method. Also, does the wire need to be supported any differently or are staples fine?
Old 12-05-2012, 12:28 PM   #4
Licensed electrician
Rewards Points: 1,780
Staples will probably come through the side of the cabinet. I sleeve the cable in plastic Panduit clamshell and use an old work box.
oh'mike (12-05-2012)
Old 12-05-2012, 02:58 PM   #5
Rewards Points: 150
You could consider using the "old construction" 1 gang boxes. Instead of drywall/sheetrock, you would just install the box onto the cabinet wall.
Hope this helps.
Ps. More importantly, IMO, you need to make sure it's to code. You should have a GFCI-protected outlet if it is right next to the toilet/tub...
oodssoo is offline   Reply With Quote
Old 12-05-2012, 03:37 PM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
In bold ^^, Stickboy will be chiming in
Coastal South Carolina
Old 12-05-2012, 04:37 PM   #7
Electrical Contractor
jbfan's Avatar
Rewards Points: 552
It's not for protection, but cable managment!
Old 12-05-2012, 05:21 PM   #8
Correct JB, I don't see the inside of the cabinet as a place that needs conduit to protect the cable. The panduct is slim enough to stick to the cabinet and keep the cable out of the way.
Old 12-05-2012, 06:42 PM   #9
Rewards Points: 332
Is the vanity you're wanting the receptacle installed into in this trailer in the photo?
sgip2000 is offline   Reply With Quote
Old 12-05-2012, 06:46 PM   #10
Rewards Points: 89
Okay sounds like my plan was good to go. Old construction one gang box and I already have a GFCI at the beginning of the run. Was more worried about securing the romex correctly.
One more question..what would you all recommend for the wire coming out of the drywall? I'd rather not just run the wire through a hole in the drywall. Is there some type of plate I can use or something to make it look more clean? I'm going to go look around on google now but figured it wouldn't hurt to ask.
Old 12-05-2012, 06:59 PM   #11
jbfan's Avatar
Rewards Points: 552
Is the wire going to be visable?
Old 12-05-2012, 07:45 PM   #12
Rewards Points: 89
Come out the wall but inside the cabinet and then travel to the single gang box.
Old 12-05-2012, 07:59 PM   #13
jbfan's Avatar
Rewards Points: 552
I would do nothing with it.
Outlet wiring; hidden ground wires Cahill_Main Electrical 4 11-26-2012 06:32 PM
Before I close walls: hard wiring under cabinet lighting with Romex. jws3 Electrical 6 08-29-2009 12:24 PM
Under cabinet lighting direct wiring Schwarzaroo Electrical 5 12-30-2008 09:25 PM
Wiring a new outlet advice kennykenny Electrical 19 08-29-2008 10:54 AM
Troubleshooting bedroom outlet wiring? Operator4819 Electrical 15 04-01-2007 08:10 PM
