Wiring Outlet For Electric Dryer - Electrical - DIY Chatroom Home Improvement Forum
Old 11-26-2007, 10:06 PM   #1
wiring outlet for electric dryer
i installed a double pole 30amp disconnect, red and black hot wires to disconnect. white ( nuetral ) and ground to bar . used 10-3 romex wire. at plug x and y wired black and red w wired with white ground to box. when checking x to w and y to w only getting 120v reading. what is wrong i need 240v across x and y to get element working.
TSMO is offline   Reply With Quote
Old 11-26-2007, 10:11 PM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Measure between x and y and you will get 240 volts if you used a double pole breaker in the panel. This will give you an idea.....it's a receptacle for a dryer
Old 11-26-2007, 10:14 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Originally Posted by TSMO View Post
i installed a double pole 30amp disconnect,...
Describe this disconnect.
Do you mean breaker?
What kind of panel is it?
In some GE and FPE panels you can mistakenly install a two-pole breaker on the same buss in the panel giving you the symptoms you describe.
Old 11-26-2007, 10:15 PM   #4
Electrician philosopher
That graphic is awesome, Stubby.
Andy
Andy in ATL is offline   Reply With Quote
Old 11-26-2007, 10:16 PM   #5
He's highly skilled.
Old 11-26-2007, 10:20 PM   #6
UAW SKILLED TRADES
Stubbie's Avatar
Yeah, paint is a highly skilled software package guys...........
Old 11-26-2007, 10:22 PM   #7
Between x and w and y and w you are supposed to have 120v. If x and y were on the same leg the voltage would be zero between x and y.
spebby is offline   Reply With Quote
Old 11-26-2007, 10:51 PM   #8
UAW SKILLED TRADES
Stubbie's Avatar
After re-reading your post you say you used 10/3 to the plug at the plug you say you connected ground the box. There should also be a connection for ground on the plug for a 4 wire to be correct.
Is the plug a 4 prong or 3 prong plug?
Dryer on the fritz.. wiring problem? cisco10 Electrical 17 11-19-2009 02:26 PM
Clothes Dryer / Outlet homercavazos Electrical 8 10-30-2007 05:14 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
Wiring an outlet in the garden wackerjr Electrical 8 05-28-2006 09:18 AM
wiring for a dryer irish_hood Electrical 4 01-11-2006 02:27 PM
