-   -   wiring outlet for electric dryer (http://www.diychatroom.com/f18/wiring-outlet-electric-dryer-13807/)
TSMO 11-26-2007 09:06 PM
i installed a double pole 30amp disconnect, red and black hot wires to disconnect. white ( nuetral ) and ground to bar . used 10-3 romex wire. at plug x and y wired black and red w wired with white ground to box. when checking x to w and y to w only getting 120v reading. what is wrong i need 240v across x and y to get element working.
Stubbie 11-26-2007 09:11 PM
1 Attachment(s)
Measure between x and y and you will get 240 volts if you used a double pole breaker in the panel. This will give you an idea.....it's a receptacle for a dryer
Speedy Petey 11-26-2007 09:14 PM
Originally Posted by TSMO (Post 76514)
i installed a double pole 30amp disconnect,...
Describe this disconnect.
Do you mean breaker?
What kind of panel is it?
In some GE and FPE panels you can mistakenly install a two-pole breaker on the same buss in the panel giving you the symptoms you describe.
Andy in ATL 11-26-2007 09:15 PM
That graphic is awesome, Stubby.
Andy
Speedy Petey 11-26-2007 09:16 PM
He's highly skilled. :thumbsup:
Stubbie 11-26-2007 09:20 PM
Yeah, paint is a highly skilled software package guys...........:)
spebby 11-26-2007 09:22 PM
Between x and w and y and w you are supposed to have 120v. If x and y were on the same leg the voltage would be zero between x and y.
Stubbie 11-26-2007 09:51 PM
After re-reading your post you say you used 10/3 to the plug at the plug you say you connected ground the box. There should also be a connection for ground on the plug for a 4 wire to be correct.
Is the plug a 4 prong or 3 prong plug?
