Wiring An Outlet In A Desk - Looking For Advice - Electrical - DIY Chatroom Home Improvement Forum
Old 01-14-2013, 01:52 PM   #1
Question
Wiring an outlet in a desk - looking for advice
Hey guys!
Im not an electrician - but I am familiar with some, basic wiring. Im writing here because im not sure how to exactly go about doing what im looking to do.
I am building a workstation/desk with a wood top, and 2 1/2" steel square tubing as the legs/structure - and I would like to build an outlet into the beam going across the table underneath so that I can conceal all the wiring inside the tubes. I could just stick an extension cord in there and be done with it - but id like to cut precise holes so that an outlet plug thing can fit in it. I hope you can understand what im talking about
My question is, what would be the best way of going about wiring 3 outlets into this beam?
Thanks!!!
thefiend1 is offline   Reply With Quote
Old 01-14-2013, 02:16 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,944
You could use snap-in receptacles, as are commonly installed in furniture and appliances:
http://www.amazon.com/Leviton-1374-1.../dp/B003AUK944
Nor you could cut a rectangular hole the size of a Decora duplex receptacle and install that:
http://www.amazon.com/Leviton-5325-W...ora+receptacle
It's a rectangular hole either way. With a snap-in, there are no fasteners required and it takes up very little space. You do not need access to the back side for installation. With a Decora, you get a duplex receptacle, but you need screws to hold it in place, and it will almost certainly require access to the back unless you are very creative.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 01-14-2013, 04:37 PM   #3
Oooo, that first link looks promising! If I were going to put 3 outlets in, would I wire each one together as 1 and then attach a power plug cable to that?
Thanks again!
Old 01-14-2013, 05:19 PM   #4
chitownken's Avatar
Rewards Points: 510
Check out http://www.mockett.com/furniture-hardware/ They make outlets, etc. specifically for office furniture.
I have used their items, and the quality has always been top notch.
chitownken is offline   Reply With Quote
Old 01-14-2013, 05:22 PM   #5
Yea I thought about going that route until I saw the prices. That stuff is outrageously expensive for some odd-unknown reason... plus for what I want to do, this wont work.
Old 01-14-2013, 06:59 PM   #6
You would wire all the receptacles together to a power cord. I'd probably buy a good quality extension cord of the appropriate length and cut the end off of it. Since the desk is metal, you will need to connect the frame to the ground wire for safety.
Old 01-15-2013, 05:45 PM   #7
Why would I need to attach the ground wire of the extension cable to the steel leg? Doesnt the ground wire usually just go into the wall with the rest? (3 prong plug).
The entire table wont be steel, just the legs.
Old 01-15-2013, 06:17 PM   #8
Electrical Contractor
jbfan's Avatar
Rewards Points: 490
You would need to bond the metal parts so if the wires shorted, the breaker would trip.
You don't want the metal legs to become hot in case of a short.
The Following User Says Thank You to jbfan For This Useful Post:
mpoulton (01-15-2013)
Old 01-15-2013, 07:26 PM   #9
By putting receptacles in your furniture, you are making an electrical appliance. Metal parts of electrical equipment need to be bonded to ground for safety. Otherwise scraped insulation or a loose connection could electrify the metal table parts. That would be bad. Grounding the metal parts ensures that the breaker trips if there is a fault.
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 04:14 PM
Help wiring new outlet Wnt2bsleepin Electrical 15 09-08-2011 11:53 AM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 03:59 PM
Troubleshooting bedroom outlet wiring? Operator4819 Electrical 15 04-01-2007 08:10 PM
