Wiring Outlet Boxes, Steel Or Plastic? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-19-2008, 01:33 PM   #16
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
You can use them they generally are just a little smaller in cu.in than those that are outlet boxes. Bottom line get a good size box for your receptacles a good one is the carlon blue 22 cu in outlet/switch box....
Is your gray box a carlon or pass and seymour?
Old 07-19-2008, 11:14 PM   #17
liscenced electrician
Rewards Points: 538
junction boxes suck, don't put any in on a new installation..... also, plastic boxes are the way to go on residential. also, think about it like this, if you have 12/2 running into your panel, you want to run #12 for that whole circuit, if you have #14 going to the panel, you want 14 for the whole circuit.
jimmy21 is offline   Reply With Quote
Old 07-20-2008, 12:05 PM   #18
the Musigician
DangerMouse's Avatar
thanks guys
i got 20 22cu" dark blue Carlons now, so gray for the switches, blue for the outlets, yes? i got the deeper boxes because i will be using mostly 15a gfci outlets and they seem to be more comfy in the bigger boxes...lol.
tnkx again!
DM
Blue plastic receptical/switch boxes used as junction boxes? alexz Electrical 7 04-09-2013 08:40 PM
Wiring Sequence on Adding a New Outlet kennykenny Electrical 9 06-09-2008 02:06 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 03:59 PM
plastic or metal boxes for outlet wiring? yummy mummy Building & Construction 9 12-31-2006 01:37 PM
Wiring an outlet in the garden wackerjr Electrical 8 05-28-2006 08:18 AM
