Wiring An Outdoor Outlet #2 - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-29-2012, 04:04 PM   #16
Electrical Contractor
jbfan's Avatar
Rewards Points: 488
Originally Posted by Macro View Post
Then you won't be able to use that circuit, but you should be able to pull a new one from the panel. It would be even easier than using the existing circuit since you won't have to try and find enough slack in the wires to splice in the receptacle.
Other than the problems of getting the pipe off and having enough slack, why can't he use that circuit?
jbfan is online now   Reply With Quote
Old 05-29-2012, 04:14 PM   #17
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Open up your existing panel, and LB, disconnect the wires in the panel, pull them out of the LB, cut off the LB carefully not to damage the existing wires, install a FS box, pull new wires from the panel to the new FS box... pretty simple IMO...
The Following User Says Thank You to stickboy1375 For This Useful Post:
Code05 (05-29-2012)
Old 05-29-2012, 04:23 PM   #18
Code05's Avatar
Rewards Points: 1,104
Yep, but then again we do it all the time. DIY forum means that many need baby steps, of course i do not always follow my own words.
Code05 is offline   Reply With Quote
Old 05-29-2012, 06:42 PM   #19
E2 Electrician
I think the OP already did some research and is way ahead of the game, he just wanted some reassurance on his thoughts.
Eusibius2 (05-29-2012)
Old 05-29-2012, 06:45 PM   #20
E2 Electrician
Originally Posted by rjniles View Post
I would drill a hole in the side of the LB and install a 1/2" male adapter and run a short piece of conduit to a new box for the GFCI. Might be a minor code violation (modifying a UL listed device).
You may not have enough slack in the LB to make a splice. I would make a new run back to the breaker panel.
That is pretty tacky if i do say so myself...
Old 05-29-2012, 07:00 PM   #21
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
To each his own but I do not think many inspectors would red tag it.
Coastal South Carolina
Old 05-29-2012, 07:03 PM   #22
E2 Electrician
I think they would.
Old 05-29-2012, 07:05 PM   #23
I don't like using 110.12, but I think this might qualify. It's very hackish.
In addition to that, it's against code. There are situations where it is permitted to support the box with raceways, but this isn't one of them. Check out 314.23.
I also wouldn't consider that LB to be accessible anymore, but that's up for debate.
Macro is offline   Reply With Quote
Old 05-29-2012, 07:26 PM   #24
Licensed electrician
Rewards Points: 1,622
The fitting would still be accessible. RJ is talking about adding another place to take off another conduit like out of the side.
rjniles (05-29-2012)
Old 05-29-2012, 07:29 PM   #25
Yes, I am sure you are going to be happy to hear that I screwed up. I confused rj's post with curiousB's. I thought he was the one who said to install a box to the open face of the LB, doing that was what my post was in response to. Sorry guys.
Old 05-29-2012, 08:47 PM   #26
E2 Electrician
Originally Posted by curiousB View Post
Along those lines how about a weatherproof box with the hole in the back. Remove LB cover and throw away. Drill a couple holes in back of box to line up with screw holes of LB and screw the box in as the cover to the LB (reuse the LB cover gasket). Just be sure to center the knockout in back of the box is in the middle of the LB. Then wire in GFCI in the front of the new box. Install weatherproof cover as normal. Only modification is two 3/16" holes in back of box.
Absolutely no...
Old 05-29-2012, 09:46 PM   #27
still remodelling....
So here's my thoughts - I would really only want to replace the LB with a new box, not add on another box. What you all didn't realize is that this is on a wall that is next to a new patio, so I'm not going to add another box (either on top of, next to, or whatever). That would look tacky. It's either all or none here.
As for an inspector finding it in the first place? Highly unlikely, but true - it's possible I guess. They'd have to walk around into my back yard past my akita first. He doesn't like strangers. LOL I'm not opposed to breaking the rules, if the rules don't make sense. But sometimes, rules are rules.
After looking at it a bit more, I would have a tough time getting the LB off the conduit in the first place since it looks like there is a bit of locktite or something there too. Not easy to just take it off, which looks like it might foil the whole plan. I'm gonna look for another alternative at this point. Thanks for all the answers!
Eusibius2 is offline   Reply With Quote
Old 05-29-2012, 09:47 PM   #28
Admitting defeat is an honor that many men will never achieve. So you screwed up. Who cares!
Help with wiring issues on a newly purchased house ThatGuy Electrical 13 01-17-2012 10:51 AM
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 09:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 09:46 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
