Wiring An Outbuilding - Electrical - DIY Chatroom Home Improvement Forum
Old 02-27-2011, 04:39 PM   #1
wiring an outbuilding
I want to wire a workshop that is 30 feet from the main panel. I wanted to add a 30 amp GFCI to the main panel and run wire underground to the shop and a subpanel with two circuits 15 amp for lighting 20 amp for saws. What size wire do I need to use and is 30 amps too much or will 20 get me by running one tool at a time?
Zman1 is offline   Reply With Quote
Old 02-27-2011, 05:23 PM   #2
Rewards Points: 320
This is a detached building? If you are going though all the trouble of trenching a line I would use a minimum or #6 and a 60 amp sub panel. That way you will have future expansion needs without having to do it over in the future. You do not need to use a gfci to feed the sub panel. The individual circuits that are run from the sub panel may need gfci protection.
teamo is offline   Reply With Quote
Old 02-27-2011, 06:23 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 386
I agree with teamo. Unless local codes dictate, there is no need to used a gfci breaker to feed the building.
Old 02-27-2011, 07:04 PM   #4
Thanks for your response and yes it is a detached building and will be fed from the garage. What about ground rods - necessary?
Old 02-27-2011, 07:30 PM   #5
jbfan's Avatar
Rewards Points: 386
Yes.
2 hots, a neutral and a ground wire needed from the garage to the building.
Ground and neutral seperate in the building panel, gorund rod connecto ground from the garage.
Old 02-27-2011, 08:47 PM   #6
Rewards Points: 212
jbfan i am thinking of doing the same thing, but i do not understand the need for the ground rod it the subpanel has a ground running to it from the main panel. could you please explain the need for this.
bluebird5 is offline   Reply With Quote
Old 02-28-2011, 06:24 AM   #7
Rewards Points: 742
Because the NEC requires it.
Mark
busman is offline   Reply With Quote
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
Outbuilding wiring and underground wiring questions tpagel Electrical 7 07-08-2008 08:38 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
