Wiring Out-building Questions - Electrical - DIY Chatroom Home Improvement Forum
Old 03-15-2009, 10:51 PM   #1
Wiring out-building questions
Ok, I have seen a number of postings regarding wiring a detached garage but am still not sure what is the best option for me.
I'd thought I'd go underground by sawing cement. The old set up was overhead. I think we could go everhead cheaper. So my questions is:
What is the best way to route the wire? I have about a 15 foot run and had planned to run the wire under a patio (via trench). Now I am thinking overhead is cheaper (wire will be about 12 feet high). What do you all think?
Also, can I run two wires from the house to the garage and then ground via ground bar?
Orher suggestions?
Thanks and have a great Saint Patricks Day!
bryan511 is offline   Reply With Quote
Old 03-16-2009, 11:33 AM   #2
Rewards Points: 160
You can run the circuit overhead or underground. That is your call. 12' is high enough to meet the requirement. However, I prefer underground. Maybe another path away from the slab?
You can only run one circuit or feeder to the structure. How much power do you need?
Old 03-31-2009, 07:49 PM   #3
Thanks!
Pardon the delayed response! Thanks for the valuable info. Any suggestions on info that will help me usderstand electical pipe fittings (i.e. diameter and compatability). I was totally confused at Lowes this afternoon!
Exterior Wiring Questions elliowb Electrical 10 01-07-2009 08:01 AM
Outbuilding wiring and underground wiring questions tpagel Electrical 7 07-08-2008 08:38 AM
questions about rough wiring FanZ Electrical 4 05-31-2008 10:08 AM
Kitchen Wiring Questions Chazbe Electrical 22 04-11-2008 04:06 PM
woodshop wiring questions baldeagle390 Electrical 5 03-20-2008 08:52 PM
