Wiring Old Medicine Cabinet With Fluorescent Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 05-05-2013, 12:42 AM   #1
Wiring old medicine cabinet with fluorescent lighting
I have an old recessed medicine cabinet that my brother-in-law removed. I'm trying to reinstall it and he doesn't remember how the wiring went. This is an cabinet with two fluorescent lights and a toggle switch. Just want to make sure that we hook it up correctly.
Coming from the ballast and switch side of the cabinet there are a black, white and red wire. On the other side are a white and red wire. There is a hot and neutral coming from the house wiring. How do I hook up the wires?
Thanks for any help!
okieopie is offline   Reply With Quote
Old 05-05-2013, 12:46 AM   #2
Rewards Points: 512
Black and Red to the house Hot, Whites to the neutral.
Installation is the Reverse of Removal.
Old 05-05-2013, 06:55 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Supply to black and white on switch side. 2 wire cable to connect red and whites together.
Coastal South Carolina
Old 05-05-2013, 09:10 AM   #4
Tried this and unfortunately blew the light bulb and tripped the breaker. Thanks any way.
Old 05-05-2013, 09:11 AM   #5
I'll try this configuration - but have to get some more bulbs before I can test it. Thanks!
Old 05-05-2013, 09:38 AM   #6
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Tube style fluorescent lamps will not blow in that situation. You may have fried the ballast or starter however.
Old 05-05-2013, 12:26 PM   #7
Can you confirm what rjniles posted earlier? I'm not sure I understand exactly what he posted about the 2 wire cable to connect the reds and whites together.
Old 05-05-2013, 01:45 PM   #8
A "Handy Husband"
rjniles's Avatar
Run the feed (black & White ) to the black and white on the switch side. Connect a 2 wire cable (of appropriate size and type) to the red and white on the switch side to the red and white on the other side. Use the black in the 2 wire cable as the red.
The Following User Says Thank You to rjniles For This Useful Post:
okieopie (05-05-2013)
Old 05-05-2013, 11:23 PM   #9
Wired it up this afternoon and it works perfectly. Thanks for your help!
Old 05-11-2015, 09:51 AM   #10
Rewards Points: 2
I have this medicine cabinet. I need to buy replacement bulbs for it. Can you tell me what they are called? Thanks! Ellen
elg3e is offline   Reply With Quote
Installing under cabinet lighting trim? kcrossley2 Kitchen & Bath Remodeling 5 11-13-2012 09:38 PM
LED Cabinet Lighting - Wire Ga. - Run Lengths - 12v or 24v driver - So many ??? roundbox52 Electrical 1 11-08-2012 09:06 AM
Under cabinet lighting iceman536 Electrical 8 05-02-2011 10:18 AM
medicine cabinet question farmallih1466 Kitchen & Bath Remodeling 3 01-17-2011 09:32 PM
